SOURCE: How do I scan a 35mm film negative with my HP PhotoSmart C6180?
I regret to inform that hp Photosmart C6180 does not support scanning negatives.
Regards,
Sagarjd
SOURCE: need adapter connectfor an HP Photo Smart 35 mm slide scanner
The HP Photo Smart 35 is a USB printer. Your computer has USB ports. You can utilize an open USB port on your computer to connect the printer. What is a CS100-818035 plug?
SOURCE: The 2400 Scanner quit scanning 35 mm slides as the top lid light
problem in the driver so pls check latested driver in the internet and download it then you problem will solved
SOURCE: How can an ordinary canon pixma mp258 printer and
It can't you need a scanner that will scan negatives and slides.
SOURCE: How do I scan 35 mm slides on my C3180 all in one
Scan specifications
? Image editor included
? Integrated OCR software automatically converts scanned text to editable text (if installed)
? Twain-compliant interface
? Resolution: up to 1200 x 2400 dpi optical (varies by model); 19200 dpi enhanced (software)
? Color: 48-bit color, 8-bit grayscale (256 levels of gray)
? Maximum scan size from glass: 21.6 x 29.7 cm (8.5 x 11.7 inches)
That model does not a have an adapter to scan negatives.
For another approach I have used, an ipad with a flashlight app will allow you to use a cell phone camera or a digital camera to take a picture, and then use the software with the cell phone or a computer to "invert" the picture from black and white to normal, and save it. Problem is the negatives sometimes have a curl or need to be somehow kept flat to photograph.
