Refer to manual that came with unit page 8. It is a frost free and cycles itself, the is no defrost control.
http://www.manualsbase.com/es/manual/564743/refrigerator/frigidaire/side_by_side_refrigerator_frs23kr4aw5/
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
SOURCE: serial number
there are a few places to look for most frigidaire side by sides the model and serial number are on a tag either on the right hand inside wall of the refrig section or on the ceiling in the refrig section. on some older models though the tag may be behind the crisper drawers at the bottom. hope that helps. peyton
SOURCE: where is defrost timer located on frigidaire
Part 23 on this diagram is your defrost timer.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?diagramPageId=00003&documentId=R0311033&modelNumber=FRT17G4BD2&productCategoryId=0166000&brandId=1428&modelName=&backToLink=Return+to+part+list
SOURCE: Where is the defrost timer located on a Frigidaire
its a defrost trermostat located near the evaporator coil and defrost heater coil
Testimonial: "Thank you very much! We literally had the whole frige tore apart looking for it. We were looking on the inside, not underneath! "
SOURCE: location of defrost timer for frigidaire side by
REMOVE BOTTOM FRONT TRIM UNDER FRONT DOORS
THE TIMER I BELIEVE IS ON THE LEFT SIDE YOU WILL SEE TWO PHILIP SCREWS REMOVE AND UNPLUG THE WIRE HARNESS FROM TIMER AND VOILA!
Hey friend, thank you for the post!
From my understanding you are trying to set your Frigidaire refrigerator into defrost mode. In order to be able to provide you accurate information on how to do so could you provide me with your model number please? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side in a top mount. But on a side by side and a French door refrigerator it can be found on the right hand side. I look forward to hearing back from you. -Matt
