SOURCE: NEED INSTRUCTION MANUAL FOR STARBUCKS BARISTA TYPE SIN 006
Saeco made several models similar to the Barista type, but slightly different cosmetically. If you have the a Starbucks model, it is the same as the Rio Vapore. You can find an operating manual, along with parts and repair diagrams at partsguru.com. I'd download all of the manuals and diagrams in case you need them in the future. Here's the link (I have not had any dealings with partsguru.com personally).
http://www.partsguru.com/SaecoRioProfi.html
SOURCE: Casio exilim z-75 bettery charger
Use a PP3 battery. Get 2 pieces of thin wire. and strip off about 2Cm from one end on each wire and about 5mm on the other. Wrap the 2cm stripped end of. one of the wires around the smooth round post on the battery (the + terminal) and twist it round tight so it is secure. Carry out the same with the other piece of wire to the Castle connector on the battery (the - terminal). Touch the lead from the + terminal on the PP3 to the terminal that is marked + on the exilim battery, and do the same with the lead from the - terminal on the PP3 to the terminal that is marked - on the exilim battery (don't worry about the terminal marked T on the exilim battery. Hold the wires onto the Exilim battery for about 30 seconds and then put the battery into the charger as normal and it should work. Don't forget to take the wires off the PP3 when finished.
SOURCE: LG VZ8500 UNLOCK CODE
It should be the last 4 numbers of your cell phone (unless somebody
changed it). When your phone gets programmed, that's the default lock
code.
or
try this
in general you cannot unlock a CDMA phone.
if you are talking about the KG800, then you can go to a site such as gsmliberty.com and get an unlock code there
SOURCE: no user manual
The manual for the Rival GC8250 is:
http://www.pickyourown.org/icecream/Rival%20IceCream%20Maker%20GC8250.pdf
-Tha Mp3 Doctor
SOURCE: Hello. My friend gave me this DVD player and
You can download the required manual from:
http://www.retrevo.com/support/CyberHome-CH-DVD-300-DVD-Players-manual/id/534bh842/t/2/
On the page which opens, click on the GET MANUAL button and follow the instructions on the next page to download the manual.
Hope this solves your problem. Thanks for using FixYa.
