Question about Kenwood Food Mixers
Kenwood chef kvc50 only stays on for a second on all areas of speed control before you have to turn back to off to get another one second of action from it? Any ideas why please?
SOURCE:
SOURCE: Kenwood chef 700w
I hope you didn't buy a new one, ours stopped last week after 25 years. All that was needed were new brushes for the motor. Anyone with a screwdriver could replace them. 4Kenwood had the parts to me in a couple of days.
Posted on May 31, 2008
SOURCE: Blakeslee (Kenwood) A717 mixer speed control
I had the same problem. Had to strip the machine down to get to the motor. On the top is a moving plate with various capacitors etc mounted. On the front side there was a Capacitor (At least I think it was) with the wire broken.
I resoldered it and the machine now works fine.
I hope this helps
Posted on Jul 05, 2008
mirran
  • 515 Answers
SOURCE: Blakeslee A717 speed control
where are you from, i have phone number to agents that still provide support for A700 series.
Posted on Jul 12, 2008
  • 26 Answers
SOURCE: Kenwood Chef A701 Variable speed controller
the solution its change the capacitor or triac, normaly problems in models A701 or A901 old motors
regards
kenwoodchefrestore.co.uk
Posted on Aug 19, 2008
  • 11 Answers
IT NEEDS A REPAIR KIT.I CAN DO THIS. OR SEND A REPLACEMENT REPAIRED MOTOR FOR £25 PART EX FOR YOUR MOTOR.PLUS POST 07507400101. ****
Posted on Apr 04, 2009
Kenwood chef keeps curdling eggs
Put water in Kenwood and a bowl inside the Kenwood to hold eggs. Eggs need to be done SLOWLY. Can also add a LITTLE water to aggs as they cook to slow down curdling . Basically you need to turn Kenwood into a double boiler. Lift bowl with eggs in and out of Kenwood to control temperature and whisk away now under control. Lift bowl and cool and slow down cooking and lower back in water and Kenwood to hear back up. Keep whisking and lift and lower bowl as needed. Some melted butter doesn't hurt either!
Jan 11, 2015 | Kenwood Food Mixers
How can I service an A901 kenwood mixer, need to get top plate off.
the speed control on my kenwood chef A901 is not working
how do i fix this.
Oct 16, 2012 | Kenwood Chef Major A701 A901 Cm170 Km201...
Kenwood Chef KM400 motor speed is too slow
A failed SCR or triac will not always show visually any sign of failure. Chances are good that is all that is wrong. If mixer had been plugged in when it got wet, that is all it takes. Also check the transient voltage supressors if the chef has them. They would be identified on the circuit board. as TVS or MOV along with a number. Only number to use is the one on the component.
If you can find ratings for the old devices, just matching the basic ratings should do. Just guessing, but the SCRs should be 20 amp and 400 volt, If the old ones are a lower rating than my guess, there is no problem with using the higher ratings, if my guess is low, go with the original's ratings. Manufacturer of device does not matter as long as ratings are at least comparable.
Jan 19, 2012 | Kenwood KM400 / KM410 Chef Classic Stand...
Kenwood chef A901 food mixer speed dial only engages when pushed in
Thank you for your help. Have fixed the problem by tapping speed control shaft back into the motor housing to remove the endplay.Fault can be found by checking for in and out movement of the dial itself. there is only a small amount when correct. T W Faint
Jan 16, 2010 | Kenwood Food Mixers
Kenwood Chef - slowest speed
if you have max speed you have to replace the .1uf capacitor the 2 spring loaded screws serve far fine adjustment
Feb 02, 2009 | Kenwood KM400 / KM410 Chef Classic Stand...
Speed control not working
What model is your Kenwood ? to Kamalsalman
A901 models change triac and capacitor .. or centrifugal broken
also check if another's components is faulty.
Kenwood Chef Restore
Dec 22, 2008 | Kenwood KM800 Major Classic Stand Mixer
Difference Kenwood Chef A701 and Kenwood A901
Hello.
the difference between A701A and A901 is :
high speed outlet
slow speed outlet
planetary hub is similar . A701A, A901 and KM series
A701 Different planetary hub and fit different tools.
is not same A720 and A920 A7 = A701/A
A9 = A901 and KM
In our web site Kenwood Chef Restore in Downloads section.
you can download the compatibility of the models A700, A701 , A900 and KM series .
Regards
Oct 02, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Kenwood Chef A701 Variable speed controller malfunction. Appliance only operates on maximum speed.
regards
Aug 07, 2008 | Kenwood KM300 Chef Stand Mixer
Food Mixers Logo
65 people viewed this question
Top Kenwood Food Mixers Experts
Peter GW Fleming
Level 1 Expert
Treefrog15
Treefrog15
Yitz Diss
Level 1 Expert
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
