Computers & Internet Logo
Mark Hart Posted on Apr 11, 2019
Unlock firmware upgrade on tp-link archer c3200 router
5 Related Answers
Anonymous
  • 239 Answers
  • Posted on Dec 24, 2007
SOURCE: D-Link DI-624 wireless router is not working after firmware upgrade try
Try to unplug the router and hold in reset button for 30 seconds see if that works, you probably did that already, But if you can get your computer to respond you should be able to open software Bios. and do your firmware update from there. If not I believe a hard reset is with the router plugged in and holding reset button for 30 seconds, I don't know I sure hope that resets it for you. Thanks take care
Anonymous
  • 854 Answers
  • Posted on Sep 16, 2009
SOURCE: Where can I find a firmware upgrade for my DWL-G730 AP router?
download this
ftp://ftp.dlink.com/Wireless/dwlg730AP/Firmware/dwlG730_revB_firmware_200.bin
Manual
ftp://ftp.dlink.com/Wireless/dwlg730AP/Manual/dwlg730AP_manual_06302005.zip
Anonymous
  • 477 Answers
  • Posted on Mar 08, 2012
SOURCE: disable Nat TP-LINK TL-WR1043ND
yeap it should be the firewall, here is the manual http://www.tp-link.com/resources/software/201161017075118.pdf
think this should help you.
But if you want my expertise, make the tp-link as a router and vdsl just the internet line. connect it to router wan and buy a switch for all your devices.That should be the safest and smartest way.
Testimonial: "Hi, I've finally found some time to test the dissabling the FW and I can say that in my case it helped. I can see now from TP-LINK IP cameras connected to the VDSL modem/router. Well done guys, thank you for your help. Kvinar"
Anonymous
  • Posted on May 22, 2012
SOURCE: TP-Link TL-WR642G recovery after failure upgrade to latest firmware
may find this page helpful. http://www.dd-wrt.com/wiki/index.php...om_a_Bad_Fl ash Its not for the TP-Link router but the same principle could be applied to you with the correct firmware. Its worked for me on more than a few occasions. Providing you can ping the router via a lan cable then the chances of recovering it are very high.
Anonymous
  • 2878 Answers
  • Posted on Nov 15, 2012
SOURCE: Belkin (F5D8235-4) with Tp-Link TL-WR702N as a repeater
It needs to be configured as a repeater first.
http://www.tp-link.com.au/article/?id=397
When i upgrade the firmware and it seems error. my computer cant detect the TP-LINK TL-WR841HP V1 Router ...........
So sorry to hear that.
Your router has broken (brick) and you couldn't repair it without proper tools and knowledge. One way to solve this problem is to replace your router chip eprom.
TP-LINK TL-WR541G Router how to change the language Chinese to english
  1. Make sure you know your hardware version!
  2. Download firmware update in English from TP Link website and unzip.
  3. Connect computer to router with Ethernet cable as per manual and in your web browser window enter http://tplinklogin.net then enter user name and password (admin,admin) to access the router Configuration Utility.
  4. From the English manual note the location in the configuration utility menus of the firmware upgrade utility. I.E. Go "system tools" (last entry in menu) then "firmware upgrade" (3rd item down). I know it's written in Chinese but you can count right?
  5. Select your unzipped file location in the window and press the button beneath.
1helpful
2answers
How to update whole firmeware of tplink for w8901g
Sameer, First thing to do is establishing some facts of this router. Please look at the labels at the bottom of the unit and let me know the firmware version. Something like v1, v2 or v4. Pls look here for the example http://www.tp-link.com/lk/Article/?id=46.
You now have to connect the router to a pc with a network cable, that pc is NOT connected to the internet. For instance with a separate laptop, disable the wifi. The network cable connects the router (one of the LAN connections) to the pc.
Invoke a browser and write in the address line 193.168.1.1 with ID admin and password admin. This should open the service program from the router. Go to Firmware upgrade. And follow the rules. Generally you have to check the latest firmware in the TP-Link site and download that file to your pc. IF you have any questions we are always here to help.
Success, Fred
Error while upgrading firmware
You can try to find the old version of firmware and see if you can load it. If that fails the router is garbage.
Firmware upgrade
try reset your router first , then upgrading
Downloading failure
Follow the instructions at http://www.tp-link.com/ca/support/download/?model=TD-W8101G to help in identifying the version of the router and attempt to re-install (correct) software. If unsuccessful the router may have been damaged by the failed firmware upgrade attempt.
TL-WR740N wireless router not working
I don't have the same router, but my router requires the reset button to be pressed and held for 20 seconds. Try that. Also, I have found the manual on-line. Try the link below:
https://www.manualslib.com/manual/534658/Tp-Link-Tl-Wr740n.html
When i connect tp-link tl-wr541 tp pc one connect nd discounnect so i cant upgrade firmware to it and cant access because of disconnect
1. dowloan latest firmware for router
2.only connect router and computer with cable
3.open router page
4 go to upgrade router option,click on brouse select file then click on upload
5.after uploading router firmware ,reset router then
reconfigure router
regards
prakash
Top TP-LINK Computers & Internet Experts
 Mikey
Mikey
Menachem Grossman
Menachem Grossman
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
