Question about Konica Minolta Office Equipment & Supplies
Please help me with the code for replace toner on Konica Minolta 190f
    Sergeant:
  • 164 Answers
  • As the title says, we have a 190F which shows out of toner. Have replace toner cartridge (often), main board and both sensors that detect toner in the cartridge, has anyone else had this on this lovely machine!
  • Every new toner contains a little fuse (it is under two tiny contacts). When the user put the new toner into the printer, the fuse blows and the printer detects in this way that it has a new toner in; so if the toner has been for any reason only a moment into the printer cannot reset the message of add new toner.
  • You can test the continuity between the contacts.
Solution A: put in a brand new toner and use the other(s) first of the natural end (so the message is not yet displayed)
Solution B: find a pico fuse of the same value and put it place. (if you are a tech you know the value, it the same in fuser or TBU ). Aldo
Posted on Apr 20, 2019
SOURCE:
checkitright
  • 1362 Answers
SOURCE: konica minolta Di3510...C0500 troubleshooting
C0500 refers to a low fuser temperature. You can attempt to clear the code by using the tech rep service mode.
Go to "Counter"
Go to "Trouble"
Trouble reset
If "warm Restart Swich" is asked for- This can be actuated through a small access hole on the right side of the control panel, using a straightened paper clip or something similar.
You may need to clear the counter by pressing "clear" and then "end".
After clearing the code, power cycle the copier. If it comes to "ready" you are all set. If not, you may have a blown heat lamp or thermal fuse which would need to be replaced by a technician. Good Luck!!"
Posted on Oct 31, 2007
  • 38 Answers
SOURCE: how do i replace the
When you open the door to access the toner and waste toner area, you will see a letter "K" on the left side of the waste toner box, and a thumb screw on the right side of the waste toner box. Immediately above the letter "K" there is a raised area in the brown plastic housing. It is between the blue toner cartridge, and the waste oner box. There is a second raised area 2.5 inches at a 225 degree angle below the thumb screw on the right side of the waste toner box.
If you will place your thumbs on the raised areas and your forefingers on the white plastic rear cover of the waste toner box immediately below the raised areas and squeeze your fingers towards your thumbs, the waste toner box will come forward at the top of the box. You can then lift the waste toner box up and out of the printer.
Please squeeze carefully if you think your waste toner box is close to full as you may inadvertently find waste toner all over the place.
The two blue caps on the back of the waste toner box are to keep the waste toner in the waste toner box instead of your carpet.
Installation of the new waste toner box is the reverse of the above procedure. The new waste toner box almost snaps in place.
Here in California waste toner is considered a hazardous material and must be disposed of properly.
Posted on May 14, 2009
  • 192 Answers
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
Posted on May 20, 2009
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
SOURCE: My Konica Minolta MC2300DL will not print. It is
You can change the 2300's menu setting to ignore empty toner cartridges and keep printing. There are 2 steps:
Step 1:
Press Menu/Select, then "right arrow" until you see ENGINE. Press Menu/Select again and then "right arrow" until you see TONER EMPTY. Press Menu/Select and you'll see STOP. Press "right arrow" once to change to CONTINUE. Press Menu/Select.
Step 2:
Press "right arrow" until you see AUTO CONTINUE. If set to ON, press the "Cancel" button and you're ready to print. If set to OFF, press Menu/Select, then right arrow to change to ON, then Menu/Select to enter. It will say "ON IS SELECTED." Then press the "Cancel" button and you're ready to print.
Posted on Apr 07, 2010
Konica Minolta 190f, ask, please call service
Guess what! If you place a telephone call to a Konica Minolta service agent and mention 190f you may solve the mystery.
Apr 17, 2018 | Konica Minolta Office Equipment & Supplies
I was changing the toner of Konica Minolta biz hub 163, and it shows a message that reads service call C0070. Please, what will I do to continue my work?
Sir/Mam,
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 13, 2016 | Konica Minolta Office Equipment & Supplies
Konica Minolta 1580-MFP how to reset replace low toner message printer ?
  • Purchase OEM toner, toner has chip on it chips say toner case is empty it is empty you replacing the toner will not fix that
May 04, 2016 | Konica Minolta Office Equipment & Supplies
How to replace Konica Minolta Page pro 1580 mf toner. please tell us
is the toner 3rd party or OEM. Replace with OEM cartridge. Well the toner is not the drum you bought a drum it needs toner. ????
go this site for operator manual
Self Help Product Support Konica Minolta Business Solutions Inc
Dec 18, 2015 | Konica Minolta Office Equipment & Supplies
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
They were pretty helpful to me.
Dave
Nov 28, 2007 | Minolta magicolor 2300W Laser Printer
Error code
toner chip is gone replace cartrige
Oct 08, 2007 | Konica Minolta magicolor 2430 DL Laser...
22 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
