Question about Light Boating
I have a XPS iT 5 5 on board charger connected to my 24 volt trolling motor batteries, the only lights that are on are the battery type light and the 2 small red lights. What is the problem
5 Suggested Answers
SOURCE:
frcs68
  • 1605 Answers
SOURCE: Converting From 12/24 to Starght 24 Volt
if it is 24v. then you need to connect 2 battery in parallel. since the battery is only 12v.
if one battery is shoing red and the other is sohwing green, that means you are using 12v only, not the 24v.
connetion as follow:
positve of battery 1 to the motor, the negative of battery 1 to postive of battery 2. the negative of battery 2 to the motor.
Posted on Oct 20, 2008
  • 53 Answers
SOURCE: I just bought a 74 lb Minn Kota trolling motor
I have uploaded a image of the wire system. folllow it carefully. the fuses rating should be no more than than thirty amp. go to your local outboard dealer they sell inline breakers that are designed for trolling motors. i prefer them because you don't have to replace them after a overload. you just reset the breaker.de79e02.jpg
Posted on Nov 04, 2009
agent91
  • 2100 Answers
SOURCE: 24 volt trolling motor wiring
Just like a flashlight. Positive to neg, In a loop going to the motor. That is the jump between the batteries, One red wire coming in from motor, it will go to pos, from one battery, the neg will go to the 2nd battery pos. From the 2nd battery neg will go to the motor. That is it, one jumper connecting the 2 batteries, will create the 24 volts. Hope this helps.
Posted on Mar 23, 2010
Testimonial: "thank you very much "
  • 53745 Answers
SOURCE: Show proper battery hookup for 24 volt trolling motor, 2' 12 volt batteries
to get b24 volts from 2 x 12 volt batteries
connect the negative (- ) terminal of one battery to the ground point on the motor
next connect the positive terminal (+ ) of that same battery to the negative terminal of the next battery
connect the positive terminal of the last battery to the power terminal of the motor
so it will be negative to ground , positive to negative , positive to motor or motor control
(-) to ground (+ ) to (-) , (+) to motor
That is called a series connection and increases the voltage available
Posted on Mar 23, 2017
My son and I have 2 12 volt batteries which should be drawing 24 volts to our trolling motor but is not. We have a separate 12 volt starting battery what is going on.
If you connect 2 12 volt batteries in series to get 24 volts and you don't get it, then one of the batteries has a bad cell or you have a poor connection between the two.
Apr 26, 2016 | Boating
Hooking up a 36 volt charger to three 12 volt batteries in series
first of all do you have 3 or 4 batteries your cranking battery is not to be wired into this 36 volt if you have 4 batteries you have 3 for trolling motor and 1 cranking battery look on your charger see if the banks or numbered 1 2 3 4 .... you got to find what battery is # 1 depends on how they hooked in series if you hook charger on wrong battery most the time a red light comes on telling you wrong battery move wires till green lights come on all batteries.# 4 goes to cranking battery if you only have 3 batteries you don't have 36 volts you have 24 volts and a cranking battery if so # 3 goes to cranking battery
Aug 29, 2013 | Minn Kota Boating
Minn Kota mk25 light will not move from yellow to green. I have moved the connections from one battery to another. I replaced a dead starter battery, and my trolling battery tested out at 100%. what could...
Do you remove the trolling motor wires before charging..? ...If not.. try that......mine started taking a LONG time to charge.. after I remove the trolling motor cables.. it take less time and charges better!!!
Feb 25, 2013 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
24 volt trolling motor (motorguide) not working. Have 24 volts at receptacle in hull of boat but when I plug in the trolling motor and check the volts on the plug, I only read 6 volts. Any idea whats...
You have a high resistance short either inside the wiring or the lower unit. This will cause a voltage drop. I would be very careful not to keep it connected too long cuz the battery is trying to keep up with the current demand and may explode.
Oct 03, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
How to wire up 24v minn kota to batterys
if you are trying to wire the batteries for teh 24 volt motor then you need to connect the positive of one battery to the negative of the other battery. then connect the trolling motor to the remaining two terminal of the batteries.
if you are trying to connect the charger to the batteries then each battery should have its own set of wire coming from the charger.these wires should be connected to the batteries in a set not crossed between batteries.
Feb 13, 2011 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
Mar 22, 2010 | Boating
How do you hook up the 2 batteries to a 24 volt motorguide trollong motor
To get 24 volts from two batteries they are wired in series. A wire is connected from the "+" terminal of the first battery to the "-" terminal of the second battery. Your trolling motor is connect to the "-" terminal of the first battery and the "+" terminal of the second battery. You will be operating at 24 volts.
Jul 12, 2009 | MotorGuide Electrical Supplies
Diagram of 36 volt hookup for trolling motor, i have a factory 24 volt wiring in my boat and I need to turn it into a 36 volt please help thank you
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
This is only a solution for 3 battery system.
For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
budman772357@embarqmail.com
Mar 01, 2009 | Minn Kota Boating
Oct 20, 2008 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Boating Logo
Top Light Boating Experts
ray gallant
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
