This is a TWO person job as car and van doors are heavier than you expect them to be. The door itself is simply bolted in place through each hinge. With the door wide open get a helper to support the door. Unscrew the BOTTOM hinge first where it bolt to the car. These are easier to get to. Then move to the top hinge. You might need a specialist tool referred to as a "Torx" socket. Some vehicles have hinges that are specific as Top and Bottom so mark them if you remove them from the door itself.
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
