SOURCE: complicated GE clock radio/CD player
To set the time:
Hit the SET Wake/Time Button closest to the CD player until the clock face appears in the bottom left hand of the display.
Use the TRACK Rev Search Fwd Arrows to adjust the time.
Rev will decrease by minutes and Fwd will increase by minutes.
Hope this helps.
SOURCE: Need to know how to SET THE CLOCK ON MY TRUCK RADIO and CD PLAYER
I have a 2001 Ford F-150 XLT pickup. Hope this works for you.
1. Hold down the volume button (also the on/off button)
2. Press the RDS button until it says "select hour" or "select minute"
3. Change it with the up/down select arrows on the top right.
SOURCE: Clock Setting
Press SET to enter time setting mode. Use the TRACK/SEARCH/TUNE buttons to select the correct time. Press SET to save clock time.
Try this, put the key in the ignition and let it be on the first
turn right marked "ACC" or you can turn off the stereo and you will notice that
only the Digital Clock screen will show. Turn the Volume/Audio/Sel knob and press
on the "DISP" button simultaneously for about 4 seconds then release the "DISP"
button. The digital clock will start blinking, and then use the Tune/Seek
arrows pointing up and down to change the time. If the hour digit is blinking change
the hour and after you have changed it press "DISP" then the minute digit will
start to blink change it using the arrows, when you are done press "DISP" again
or leave the clock for between 4 to 8 seconds the clock will start working
normally. I hope this works for you. Good luck! Aquinas
