Saws Logo
Anonymous Posted on Apr 11, 2019
How do i repair my chicago electric professional 5 double cut saw when it died while cutting wood
bobpride
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Apr 11, 2019
bobpride
Contributor
Level 1:
New Friend:
Answers
22
Questions
0
Helped
7460
Points
54
You probably should buy a new one if the motor failed. Is warranty replacement a possibility?
Manual for PowerShot item 9000 Electric Staple & Nail Gun Mfg by PowerShot Tool Co. Inc
Track Saw vs Circular Saw-which is best for your project March 19, 2020 By pervezWe use a saw for cutting wood or any material. In the market, we can find a lot of saws and it will do our desired work. If you are a woodcutter then a track saw will help you. A track saw is a handheld circular saw, on the other hand, a circular saw is one kind of power saw which helps to cut woods or any material.We can use track saw and circular saw for cutting woods and other materials like tile, brick. But there is a difference between them. We have to know what is Track Saw vs Circular Saw. see the difference between them given below.
Track Saw vs Circular Saw Lets Have a quick look into these A user uses a saw for different cutting purposes circular saw and track saw is one of them. The track saw is used for cutting woods and circular saw also used for cutting woods too But both of them are used for different purposes.
Circular Saw
We use a circular saw for cutting woods and it uses a round blade lined sharp metal blade. A circular saw is used for cutting woods, plastic, metal, and masonry. Circular saw is an electrical saw and it runs through electricity. There are some things in a circular saw and they are-
  • An on/off switch
  • A handle and upper guard
  • A cutting blade and lower blade guard
Safety Procedure Circular saw is a powerful tool and it is dangerous too. A user must wear safety equipment while using this circular saw. Moreover, this tool can produce a lot of dust so better is use masks for it. We have to hold the saw perfectly with both hands so that it will not move from the place.
If you have enough time then you may go through the article- Top Circular saw Buying Guide.
Track Saw
The track saw is a handheld circular saw and this helps a user to cut logs accurately. A track saw can cut any log faster than a circular saw because they are lightweight and portable. The layer on a track saw creates an effective dust trap and also doesn't just enclose the blade.
The track saw is suitable in any situation because of its rubber strips at the bottom. It is easy to cut and no need for measurement and it can make a big cut into small pieces.
The Benefit of Track Saw
  • A track saw is easy to move
  • Smooth and clean cuts
  • Long meters for cutting any objects
Mainly a track is easy to move from one place to another place and it will give a user smooth and clean cuts than other saws in the market. Easy to cut no measurement needs to cut a log or any material just line it up and cut it. No guesswork or measurement is needed to cut woods.
Should a User Choose a Track or Circular Saw? A track saw and circular saw both of them these are using for cutting any material or woods or a tile or metal and plastic things. The track saw is one kind of circular saw which is portable and easy to use than a circular saw.
A circular saw is a powerful and electrical saw. The user has to be careful while using this saw because any single mistake can risk his life. So if a user loves to use a handheld saw then he should go for a track saw and if he wants a powerful saw then he should go for a circular saw.
Circular Vs TrackSaw
Track saw and circular saw both of them use a circular blade but track saw blades are less uncover. The major and main difference between them is one is easy to move another is complex to move. Another difference is track saw provides a better cut and smooth performance than a circular saw.
Circular saw creates more dust than a track saw because in a track saw a dust filter contain on it(track saw). The circular saw is best for construction purposes because it can give you the best performance than a track saw. If you are going to cut lumber or a tree on a roof than a circular saw can help you better than a track saw.
So better is if a user wants to use a portable lightweight saw than track saw is better for him. But if he wants to use a saw that provides more facility than circular saw is for him.
Final Words Both of this saw is perfect for cutting wood or any kind of material. A track saw is portable and lightweight on the other hand a circular saw is more powerful than any other saw. You can carry a track saw with you in your shoulder but can't carry a circular saw with you.
So if you want a lightweight saw then track is for you or if you want a powerful saw then circular saw is for you.
Filed Under: Guide
Trying to find a black @decker electric hand saw
Electric hand saw has become a must-have power tool once you have a woodworking workshop whether it's for home usage, hobby, or industrial purposes.
https://dailytoolsguide.com/best-electric-hand-saw-for-cutting-wood/
These electric saws help you obtain more precision cuts and get the woodcutting job done more efficiently, effortlessly. However, there are different electric hand saw products for cutting wood available in the market.
Electric hand saws have variants for which they're specifically designed for. What you need is the best electric hand saw for cutting wood that suits your needs. We've listed some electric handsaw products you may consider below.
Apr 15, 2017 • Saws
1helpful
Troubleshooting chicago 7" tile saw
problem power switch
brushes worn
problem armature
circuit breaker for power point
Saw quits after cutting wood for about 5 minutes
Are you sure you have the correct amount of 2-stroke oil mixed in the gas? It sounds like it is overheating. Also check the engine to make sure the fins aren't clogged with wood shavings.
2answers
My new Chicago Electric Reciprocating saw throws the blade as soon as I start to cut. I'm pretty sure I've got the blade locked in correctly. I turn the chuck until it opens and seat the blade in...
if you want to know about saw, like different kinds of saw . you have to read through this blog
Electric hand saws have variants for which they're specifically designed. What you need is the best electric hand saw for cutting wood that suits your needs. We've listed some electric handsaw products you may consider below.
Apr 19, 2011 • Garden
2answers
Not cutting through wood. Cuts are diminishing.
Sounds like the wood your cutting through is to hard for your battery powered saw....try one with a cord they work much better, especially for hardwood's.
I cut mostly hard woods, oak, hickory etc. I just
Have the chain professionally sharpened (Stihl or Husqvarna) at a saw retailer (take your saw). While there ask them to verify the gauge of the bar and chain are the same. When you return to pick-up your chain bring a few pieces of wood. Ask them to make a few cookies with your saw. Please reply with the result.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
1helpful
2answers
Bought the makita 18 volt lithium power saw which i thought would cut a 40mm worktop in fact i struggles to cut 9mm ply is this it's limit or is there something wrong with the batteries
I have a Ridgid brand battery operated circular saw 18 Volt and it works very well for a battery operated saw. It eats 2x4's and 2x6's very well. I have noticed that when the blade only gets slightly dull it will not cut worth a darn. Keep a sharp blade on it and maybe try a different battery. A battery powered saw is NOT a replacement for a plug in saw, but they sure as heck are handy.
Cutting a 40mm worktop should be no problem unless it is a hard wood. If it is a hard wood you might need to get a plug in saw and a very good blade.
1helpful
Chicago Electric 4'' table saw. I used it to cut 1/4 inch wood then turned it off and it will not turn back on. I tested the outlet that I had it plugged into and the outlet works. I let it set for over an...
inside the motor is a thermal fuse. once it blows nnthing will work. the thermal fuse is within the winding. get another fractional horsepower motor replacement from grainger.
Oct 17, 2009 • Saws
Grinder question
Use a pencil and straight edge to mark the cutting line on the wood. Place the wood on the saw table and line the mark up with the saw. Place the mark on the right side of the blade to ensure proper cutting. Plug the saw in and put on your safety goggles. Support the wood on the work surface with your left hand, placing it far from the saw blade. Place your right hand on the handle, and push the trigger to start the saw. Move the saw blade down onto the wood. Put constant pressure on the handle to slowly move the blade through the wood. Release the trigger and raise the blade once the cut is complete. Make diagonal cuts in the same manner, by marking the wood and lining the mark up just to the right of the saw blade. Continue as you would for a straight cut. Remove the wood from the saw. Unplug the chop saw and dust the sawdust off. Remove the dust bag from the back and empty it. Vacuum any remaining dust off of the saw.
Top Saws Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Saw Expert? Answer questions, earn points and help others
