Question about Sony Video Cameras
My sony ccd-v800e I can´t put in on even with power cable connected to the charger. I have no reaction to power (display, motor, etc). I think power supply module is bad. how can I access it? Thanks
SOURCE:
SOURCE: No power -- bad power supply?
The fuse thats leads to the power supply on the sony receiver blows everytime i try to plug in the receiver. What makes this happen and what can i do to get the receiver going again. Model STR-DE135.
Posted on Oct 12, 2008
  • 19 Answers
SOURCE: no sound on playback
The S-video cable carries picture only. You need to also hook up RCA audio cables from the camcorder to the TV
Posted on Dec 30, 2008
  • 624 Answers
SOURCE: sony cdx m800 no display
I think you are going to need the service manual to properly troubleshoot this. You can try to follow these instructions without one, but having one makes it so much easier. You will need to have the radio on a work bench with the CD mech out and the harness out of the car as well so you can turn on the radio and check some voltages. Since you are an electronics engineer, I should not need to point out any safety precautions, after all, I am just a technician.
For starters, check the voltages at pins 7,8,15,16,17 on connector CNP909 the 24 pin connector for the display on the main board. Pin 1 should be the one closest to the corner of the board that connector is near. Pins 7 and 8 should have 10 volts each, pin 15 should have 5 volts and 16 and 17 should both have a much higher voltage. I suspect you may be missing the 10 volts from pins 7 and 8. If so, check the voltage at the emitter of Q914 on the main board. It is a digital transistor (surface mounted) and when the power is on it should have 10 volts there and 10 volts on the collector and zero volts on the base. If any of those voltages are not there, check Q915. It should have 10 volts on the collector, 5 volts on the emitter and 5.6 volts on the base. It is not a digital transistor but is surface mounted and much bigger than Q914. If you are missing the 5.6 volts on the base, check the zener diode D905. It should have 5.6 volts on the cathode and ground on the anode. The cathode goes directly to the base of Q915. Use your multimeter on the diode check mode and see if it looks normal. Could be that zener diode is shorted. There is also 2 capacitors in parallel with that zener, C928 and C930, check those as well. If one of them shorts out it will look like the zener is shorted.
You can also check CNP805 for the 10 volts, it is supposed to be there as well. I don't know what pin number but I think that connector is on the top of the board. The 10 volts should be either pin 5 or pin 7, depending on which side you start at. CNP805 is the connector for the sub-board with the reset switch on it. After you know what these voltages are on CNP909 we should be able to narrow down the problem.
I hope this helps, I really do not have a lot of time right now. I have a power supply to fix and a big stack of car amplifiers to repair. Let me know if you need more help, I just may not be able to answer as quick as you may like, but I will answer when I have time.
Dave
Posted on Jan 27, 2009
mrninja
  • 600 Answers
SOURCE: I have emachines T5026 and won't turn ON.when I
could be a component on the mobo (cpu,ram, or the chipset)
Posted on Sep 08, 2009
  • 700 Answers
SOURCE: I need canon gp 405 Service manual that contain
this site have service manual which contain most of requested bits, including how to and what to do. it is not for faintharted do... :-)
http://www.scribd.com/doc/16699855/Canon-GP405-service-handy
if you find my answer helpful, please rate it, thanx!
Posted on Jul 31, 2010
SONY HANDYCAM Hi8 MODEL NO.CCD-TRV228E VIDEO CAMERA RECORDER 3-087-734-01 =7.2V 4365047 SONY CORPORATION MADE IN JAPAN TO TRANSFER VIDEO TO PC
I have Sony camera recorder CCD-TRV228E PAl Hi8.....
t is working OK,but i cant see anything on the display...
Somebody told me it was something like ICT orr TCI4 chip....
Can anybody tell me something about this probllem..??
Dec 02, 2010 | Sony CCD-TRV228E Camcorder
Trying to find a cable for my sony hI8 model number ccd-trv68 to go from my camcorder to my computer?
This is an analog camcorder - not digital. Therefore, the only cables you can use are the RCA types for audio and composite video. The computer must have an adapter board or allow RCA inputs (analog).
Nov 13, 2010 | Sony Handycam CCD-TRV68 Camcorder
Background changeover unit failure [fi-5120Cdj #2 , 048005 , c2]
Hi Vivek,
Thank you for contacting Fixya.
When a background switching malfunction occurs, "E" and "F" will display alternately on the function number display panel of the scanner.
Background changeover unit failure error is detected in initial checking at power on. Probable causes:
- Insulation material damage of BW motor cable or the damage of the wire in the motor. - Defective lamp or CCD or CCD cables. - CCD Connector disconnected. - Defective Control PCA.
Solution:
Wipe the top and bottom glasses located inside the ADF with the Cleaner F1 (or isopropyl alcohol) and check if the problem persists.
1. Does the same symptom occur after turning OFF and ON the scanner? Press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON. 2. Check if the cables between the Control PCA and the BW motor damaged? Are the connectors connected correctly? Check & confirm the position of the BW motor and check the cables. 3. Check Is the CCD cable F or B damaged? Or are the connectors connected correctly? 4. Check if the OPT Unit is installed correctly? 5. Check if the white reference works properly? If not, then replace the BW Motor. 6. If the above do not resolve your issue, then you may have to replace the Control PCA or Optical unit to see if the error is resolved.
Hope the above information is helpful.Please revert if you have any doubt.
Regards,
TechSatya
Aug 18, 2010 | Fujitsu ScanPartner fi-4120C2 Path-Through...
I have a Sony Handycam Video 8 ccd-TR330E PAL.
how to transfer video to computer, any cable ? raymonddcrus@yahoo.com
Feb 23, 2010 | Sony Video Cameras
Sony DCR-HC20 displays E 61:10 in upper right corner, no zoom
I can simulate this fault E61:10 by pulling out the CCD ribbon cables. This is an error that is pointed to no signal from Camera CCD assembly. Very gently remove the screws for the LCD cover assembly and remove. If you look in the upper left corner you will notice a ribbon cable connection. There is one more connection that should be checked, and it is located in the top portion below the CCD assembly. Make sure that all ribbon cables are currently attached firmly. Take specail care in opening your camera.
Jan 05, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
HANDYCAM USE
Go to any Sony dealer ask for NP-33 battery pack for your CAM
Cheers
Dec 08, 2008 | Sony Handycam CCD-TRV416 8mm Analog...
Hello
If the display is defective we can supply it from Sony.
Check whether you can play the recorded images by connecting it to a PC.
Jul 05, 2008 | Sony Handycam CCD-TRV12 Camcorder
Open Questions:
Video Cameras Logo
67 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
