Question about Home
How do I reset a Lorell 60986 wall clock? - Home
    Top Expert:
  • 84,619 Answers
On the back of the clock movement is a serrated little wheel, turn that.
Posted on Apr 10, 2019
SOURCE:
Skyscan atomic clock problem
Look carefully at the back of your clock for a reset button. The temp may have encountered a problem and stopped working. Also, be sure the battery is fresh. Hope this helps.
May 31, 2014 | SkyScan 86709 Atomic Wall Clock
Replaced battery time will not set
place it closer to the window until it sets
Nov 27, 2013 | Lorell 60993 Radio Controlled Wall Clock
How to reset wesrminister wall chime clock
If this is a mechanical clock, make sure the chime lever is set on. If quartz there is a reset button to forward the chime advance until it matches the hands.
Mar 19, 2013 | Seiko Mantel Clock
How to reset a Seth thomas weather station wall clock
what do the boxes in the clock desplay mean and also i do not have an outside temp reading on the clock just inside temp and i do not know what all the buttons on the back of the clock mean and hou to use them the clock is a seth thomas sade weather station
Oct 12, 2010 | Seth Thomas Radio-Controlled Howard Wall...
I can't get my atomic wall clock to set on daylite La cross wall
The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
Bill B
Mar 18, 2010 | La Crosse Radio Controlled Atomic Clock
I have a radio Shack Atomic Wall Clock 63-1438 and the time didn't change on Oct 31, 2009. Should it automatically change of do I have to reset the clock?
Most atomic clocks simply receive the National Institute of Standards and Technology (NIST) time signal. They do not all allow for daylight savings time changes as not all areas use it.
You will have to adjust manually.
Nov 04, 2009 | SkyScan 86709 Atomic Wall Clock
After changing the batteries in my skyscan wall clock and transmitter, the time will not register, and the date is wrong. I've waited 24 hours for it to reset with sattelite, but nothing has happened.
Place the clock near a westerly window, if possible. It should only take a few minutes to reset. These clocks work using signals sent by terrestial radio waves, not satellites.
Nov 02, 2009 | SkyScan 86709 Atomic Wall Clock
Outside temperture
After changing the batteries on the outside unit, remove the batteries from the clock for a few minutes, then replace them. This will reset the clock to 'talk' to the transmitter.
Nov 21, 2007 | SkyScan 86709 Atomic Wall Clock
Home Logo
26 people viewed this question
Top Home Experts
Donni Steen
john h
Are you a Home Expert? Answer questions, earn points and help others
