SOURCE: Printer Stripe S-500 Zebra
The printer now is replaced, but i had changed also te printhead before. Now we use a other type of Zebra now :), more better and slower.
Thank You
SOURCE: Zebra S600 printer
SOURCE: Zebra TLP2844 does not print the barcode label
Turn off the printer, then hold down the feed button while you turn it on again. After the configuration label prints, turn the printer off and on again,then try to print your labels.
If the barcodes still don't print, make sure they don't extand past the top, bottom or side of the label. If you software allows you to "clear the label cache" or "re-image the enitre label", try that.
SOURCE: Zebra S600 will not do anything???
Emma, I can assist but this is slightly technical. The issue more than likely is the print head sensor flag is out of position. If you have the print head all the way down & purple toggle in the locked position but the print head light still flashed then more than likely it is the flag that came loose. To correct it means you have to remove the left side cover where the logic board is. Make sure to remove power cord & all communication cables & connectors prior to cover removal for your safety. After the cover is removed you will see the logic board. On the upper right corner area will be a SCREW with a black "L" shaped piece of plastic, this is the flag. At this point make sure the print head is down & locked. Place the flag in the horizontal position, which should be between the sensor positions, While holding retighten the screw. Once tight open & close the print head to see the flag move up & down between the sensors. Place the cover back on but put 1 screw in only so you can test. If all works put the rest of the screws in & continue to work. If not then update this & I will get back with you.
