SOURCE: where do i put 2 stroke oil? do i mix with petrol
its under the front of the tank take the seat off undo the allen bolt at the front right side of the tank and lift the front of the tank up there is a support rod under the tank to hold the tank up
SOURCE: how to pre-mix 2-stroke
the recommended mix is 40:1. So for 5 liters of fuel you're looking at 4.2 ounces of oil.
SOURCE: oil to petrol for 5.litre can
the fuel to gas ratio should be 50;1 50 parts oil to 1 part fuel
SOURCE: i am looking for a manual for a lawnflite 3000
check ebay.com theres alot of manuals on there that may help with your problem. i hope this helps you. jd
SOURCE: What mix of 2 stroke oil do I use for a Stihl
if using top quality 2 stroke oil
you put 100 mils of oil into 5 litre container and add 5 litres of fuel only that is 50:1 petrol oil ratio
cheers pauly46
