Question about Video Game Consoles & Games
PS3 says file corrupt restore file - Video Game Consoles & Games
SOURCE:
SOURCE: My PS3's hard disk file system is corrupted
This happened to my husbands PS3 also. He put it into another PS3 and reformatted it and then when he got home and put it back into his it asked him to reformat again and this did the trick. It's been working ever since. He called Sony and they wanted him to send back his hard drive and they would either fix or send him a "new" refurbished one for $150. I don't think so!!
Posted on May 25, 2008
There is an alternate way to restore your HDD. Turn off your system and when u see the red light, hold the power button in front until you hear a total of 4 beeps (1 alone, 1 alone, 2 together). It usually works on second try. it should show a screen and say hook up controller with a usb cord. Then it should show i think 6 options. Choose the restore option. it should work.
Hope it works and wish you all the best!
P.S.- I just got the 80010514 error on my ps3 and my ps3 games dont work anymore :(
Posted on Jan 07, 2009
flacooo1
  • 172 Answers
SOURCE: hard disk's file system is corrupted
Hi if you have the ps3 with the model # cechh01 or cechk01 or cechl01 this happen a lot you need to install the new update in a usb memory card and follow the instructions on the ps3 go to sony for instructions on how to download the update in a removable usb if you have the older models you need to format the hard drive or install another one and format the old drive in another ps3 and this can fix your problem
Posted on Mar 13, 2009
Big Hev
  • 64 Answers
This is happening because your console is not recognizing the HDD (hard drive) for what ever reason. The corrupted files are about to do damage to your console, and a PS3 will not turn on if it thinks further damage will occur. Here are two things you can do;
1. Try accessing the HDD reset menu. Here's how you do this: With a solid red light showing, hold down both the power & eject buttons. You're going to hear a single beep, then a double beep. Once you hear the double beep, release both buttons. You'll get a message on your TV saying "connect your controller using USB". Following all the instructions will lead you to a 6 item menu. You are going to choose number 3. If that option doesn't work, pick number 6. BE WARNED!!! Number 6 will delete ALL of your saved memory! I know that really sucks, but this may be the only way to save your console short of repair. You can "back-up" your saved data using a "USB storage device" Like a memory stick or even your iPod.
If none of this works, or the console just won't let you do the "double button" thing, it'll need to be repaired. You can contact PSR repairs at www.psr1.com. They are really great! They do both warranty & non-warranty repair work for a very decent price. I hope I helped. Good luck, Indra!
Posted on May 30, 2009
  • 8 Answers
SOURCE: PS3 file corruption fix!
He's right, this really will work
Posted on Feb 24, 2010
Testimonial: "This does work. Also check my post of things to avoid on your Playstation 3."
Ps3 wont come off restore file system
go to ps3 on line and down load system files to disk put it in and turn ps3 back on it will restore off the disk. some files are corrupt,
Feb 19, 2018 | OFF Video Game Consoles & Games
Playstation 3 saying hard drive file corrupted needs restoring, it restores but goes back to saying hard drive file corrupted
Hello there Sir! My name is Aleksandar and I'm from FixYa solution team.
It looks like you have real trouble with PS3 HDD corruption, I advise you to watch this short explanation video and follow the rules to make sure you fix the problem.
link is bellow:
FIX PS3 HDD CORRUPTION
Thanks on your time, contact me if you need more help!
Wish you good day Sir! :)
May 05, 2011 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console My PS3 hard disk is corrupted, It say to restore i put restore and nothing had been restored Bid
Corrupted hard disk? Lets see....
You could attempt to boot up the PS3 in safe mode and restore the file system (should delete any corrupted data). Describing how to start up your PS3 in safe mode would just be confusing, so instead here's a link to the official page on the PS3 Safe Mode feature.
Follow the instructions, and then I'd say try options 3 (Restore File System). If that doesn't work, try 4 or 5 (Rebuild Database or Restore PS3 System).
If that fails, you could just replace the hard drive. The PS3 uses standard 2.5inch SATA laptop/notebook hard drives (5400 or 7200 RPM). They can be found online at any computer parts website; for example, Tigerdirect.
If somehow the new hard drive doesn't fix it, or you don't feel like buying a new hard drive, you could send the PS3 back to Sony. If you're under warranty it's free; otherwise it's expensive (150$ I believe).
If you request the repair service, they send you a box, you put the PS3 in it and ship it back to them. A month or 2 later they send you a fixed/different PS3. Simple, but takes forever to get a working PS3 back which is why I suggest you try a new hard drive first.
Anyways, hope you get it working soon!
Mar 22, 2011 | Sony Playstation 3 (PS3) Console
My ps3 says " the
Let the PS3 restore itself. Your hard disk is corrupted unless you restore it you will not be able to use your PS3
Mar 03, 2011 | Sony Playstation 3 (PS3) Console
Hard disk file system corrupt
Bad sector or MBR on Hard drive needs replacing
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
"The Hard Disk's file system is corrupted and will be restored"
rpoulley
If you are getting the corrupted hard drive message this means that you have corrupted data on your hard drive. The link below will help you address this.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Mar 07, 2010 | Sony PlayStation® 3 (80GB) Console
Feb 24, 2010 | Sony Playstation 3 (PS3) Console
Ps3 says the hard files have corrupted and will be restored ....
jvbeaudette
Issken
Jan 24, 2009 | Sony Playstation 3 (PS3) Console
Jan 07, 2009 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
