SOURCE: Hobart 20 quart mixer
Hi im a service tech for hobart.I cant give service manuals out because i could lose my job but i can step you thru your problem with the mixer,let me know.
SOURCE: Hobart L-800 Mixer is rotating in the wrong direction
Take the top cover off.Trace the plug going into the top,there will be 4 wires,leave the green wire alone.Unplug the mixer and any 2 wires reverse them that should do the trick.
SOURCE: oil seal
1. Remove the acorn nut, hex nut, and washer that hold the "planetary" agitator section on the transmission shaft.
2. Remove the trim ring (if any) around the same.
3. The agitator section should now be able to be worked free.
4. Remove the retainer clip on the top of the agitator shaft. (Some models have a pair of hex nuts here; if so, remove those.)
5. Pry the gear up and off the shaft. Remove the square key from the shaft keyway at the same time.
6. Tap gently on the top of the agitator shaft to drive it out from the bearings and grease seal.
7. Recommend removing and replacing the top bearing at this time; it's inexpensive to replace, if you're in this deep.
8. Use a suitable diameter piece of round steel stock to drive out the lower bearing and oil seal. I don't recommend using the agitator shaft.
9. Clean thoroughly, insert a new bottom bearing and oil seal, drive in place with a rubber mallet.
10. Replace agitator shaft through oil seal and bearing, tap gently into place.
11. Fill cavity with approved lubricant. I use USP-grade mineral oil, as it is food-safe and provides satisfactory lubricity.
11. Install top bearing, tap gently into place.
12. Reverse steps 5-1 to reassemble.
SOURCE: service manual for hobart mixer s301
Give me the serial number,also hobart does'nt release their service manuals to the general public.However if you goto hobartcorp.com type in your model which is a d300 and you can access an exploded view of the parts.I work for hobart and service these mixers often.Any questions let me know.
SOURCE: Are attachments for a KitchenAid K5 compatible with the K55?
That would be incorrect. If the attachment is for a hobart kitchenaid mixer then it will fit all models of kitchenaid mixers including the brand new pro series because the attachment port and drive gear has not been changes since 1925 or 6 when it was first introduce by the Hobart company.
