SOURCE: cant find fuse for the cigarette lighter for 1991 accord
yes, its under the dash on the drivers side near the hood release.
SOURCE: where is fuse in fuse box on chevy malibu 2004
There are 2 fuse panels in car, 1 under hood and the second under drivers side of dash, above hood release area. Radio fuse should be under dash, most likely a blue(15amp) fuse. The fuse panel glossery should be on inside cover of fuse panel or in owners manual under fuses in glossery.
SOURCE: electric windows wont work cant find fuse
if it the old vitara i had exactly the same problem i shorted the fuze when trying to fix the windows and i could not find the fuze. By trial and error i found that the fuse is the round one next to the fuze box inside the car. Hope this helps.
SOURCE: cant find fuse box to change the radio fuse
check below your stering wheel ore on the passanger side for box also hanes books help you on this
SOURCE: fuse diagram for a 94 chevy k1500 pickup
check the fuses on the L/S OF DASH BOARD. OR UNDER THE DASH BOARD. ALL THOSE FUSES ARE TESTABLE THRU THE TOP 2 PINS PUT A TESTED LIGHT ON EVERY FUSE BOTH PINS FOR POWER THAT WASY YOU KNOW IF ONE DOESNT LIGHT UP THEN THAT FUSE NEEDS REPLACING. OR REMOVE EVERY FUSECHECK IT BY HAND. PUT IT BACK. THIS MIGHT HELP ................
