SOURCE: Regarding my Citizen Eco Drive E870-5017891
Well.. if your watch is automatic (battery not included) you have to take care of that watch like avoid hard shock like the watch fells from a hight etc . secondly is your watch operate on battery there much got weak or your watch hand alignment is out in this case you must get your watch to there service center and this is not a serious problem they won't charge you much for this problem ..i hope that i helped you
SOURCE: Citizen blue angels navihawk how do I set the time?
Here is the link to get the setting instructions.
http://www.citizenwatch.com/COA/English/settings.asp
SOURCE: Citizen Eco Drive second hand stoped working
The Citizen Eco Drive watches use special recharchable batteries.
I started collecting a couple of watches and I noticed sometimes a jeweler replaces them with an ordinary battery. The watch will work and at the same time it will try to recharge this one until it explodes! In newer models they made it harder to use the non-rechargable ones by adding a special connector or clip to the rechargable battery types.
Okay, if you say your battery goes bad, or watch does not run okay? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
The seconds hand should run in single second steps, if it takes steps regularly, but every 3 seconds or so, it tries to tell you that its power level is going down. It will be able to continue for one or two days, but you should get it into the sun more often.
Charging the battery under a lamp is possible, however this heats up the watch and this may reduce battery life.
As long as the watch keeps running I believe it should keep good time. It is quartz anyway. If this is not the case, and a good sunbath does not help, the mechanism could be running heavy, possibly due to overheating the watch; no help there...
If you need to know more about the Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Those are great watches as long as you remember it needs light to charge.
SOURCE: Stop Watch not resetting
pulling the crown out to position 2 and pressing button to zero it out one increment at a time is the way to do it do touch the watch hands. Works on fossil watches as well as tag watches
SOURCE: Seiko Sportura SNJ007 chrograph watch instructions
Best solution is to download the ORIGINAL INSTRUCTIONS MANUAL directly from SEIKO's main website:
http://www.seikowatches.com/support/ib/index.html
