Question about 50 HP 4WD Tractor w/ Front-End Loader & Agricultural Tires
How to wire fuel gauge on 165 massey - 50 HP 4WD Tractor w/ Front-End Loader & Agricultural Tires
How do you wire Massey Ferguson 230 diesal ? With 3 wire delco alternator. Along with oil pressure switch , ammeter, neutral safty switch, fuel,water. 12 volts.
    mages for wire diagram Massey Ferguson 230 diesel
    More images for wire diagram Massey Ferguson 230 diesel
    230 MF - wiring diagram - SSB Tractor
    www.ssbtractor.com/wwwboard/view_all.cgi?bd=massey&msg=10416
    Allen Stewart, I need the wiring diagram of the dash area. Does anybody have this? Allen Stewart, wiring diagram is needed for Massey Ferguson 230 diesel.
    [PDF]MASSEY-FERGUSON - MyeDocs.com
Jan 01, 2016 | Toys
How do I fix a clutch on Massey Ferguson 165 1979 tractor. I need a manual to do repair on farm
This is easy. If you live on a farm i assume you have some mechanic abilities. the tractor needs to be split in half. I have done these tractors in as little as 4 hrs. The easy way to seperate the tractor is to sleightly jack up the middle of the tractor,put a jack stand under the front of the transmision. Now move the floor jack forward to the rear of the engine. take roughly half of the weight off of the jack stand. this will allow you to roll the front half of the tractor away from the rear once you remove the trans.bolts,hydro.lines and brake rods.
Sep 15, 2014 | A&I Products A-509057M91,Massey...
2008 h d rode king gas geage flasing emty (TANK FULL)
For a 2008 Touring bike with the ignition switch turned to IGNITION the fuel gauge is connected to +12 volts. Current flows through the gauge and the variable resistor in the fuel gauge sending unit to ground. The sending unit float controls the amount of resistance in the variable resistor. Inoperative gauges may be caused by several different circumstances: the sender or fuel gauge may not properly or sufficiently grounded; there may be a malfunction in the sender or in the fuel gauge; there may be a broken or disconnected wire from the ignition switch to the fuel gauge; there may be corroded connections at the fuel gauge.
Test the fuel gauge system by FIRST removing the gauge, THEN ground the fuel gauge sender Y/W wire located at the bottom of the gauge, turn the ignition switch to IGNITION and the fuel gauge must indicate FULL in which case it is functioning correctly in which case set a multimeter to the RXI scale and measure the resistance of the sending unit by placing one probe on (Y/W) and the other probe on the motorcycle ground or bare chassis point as a ground. If the fuel tank is full the reading should be 30-50 ohms while an empty tank should have a 240-260 ohm resistance value and a half full tank will be approximately 125-165 ohms. If a very high resistance or infinity is indicated on the meter, the sender may be "open" or not grounded. Check that the sender and the fuel tank are both grounded by placing one probe of a Multi-Meter on the sender flange and the other probe on the engine crankcase. The meter then must indicate one ohm or less. Replace the sender if one ohm or less was present and if a higher resistance is present, check for a poor connection on the ground wire.
If when the gauge did not indicate FULL when the fuel gauge sender Y/W wire was grounded with the ignition switch at IGNITION check the voltage to the (O/W) (+) and (BK) (-) wires of the fuel gauge connector and a correct reading will be equivalent to battery voltage. If battery voltage is not present check for a broken or disconnected wire. Replace gauge if wiring problem is not foun
Apr 16, 2014 | 2008 Harley Davidson FLHRC Road King...
Trying to find out what year a Massey ferguson tractor is the serial # is 9 A 108154
1971 and appears to be one of these models. Massey Ferguson Model MF-135, MF-150, MF-165, MF-175 and MF-180
Mar 06, 2014 | John Deere Tractor 1020, 1520, 1530,...
Where would i find the chassis number on a massey ferguson 3115
Climb up into the tractor's seat. Look below the lower left-hand side and lower right-hand side of the steering wheel panel for the serial number. Certain older Ferguson tractors have the serial number stamped to a plate that is mounted to one of these areas of the steering wheel panel.
Serial Number Plate:
http://old20tractorparts.com/mf-165-tinwork-parts/1356-massey-ferguson-165-serial-number-plate.html
Inspect the left- and right-hand sides of the tractor's main frame. Certain older Ferguson tractors have the serial number stamped to a plate on the outside of one of these areas of the main frame.
Inspect the top of the transmission housing for the serial number. Certain older Ferguson tractors have the serial number stamped to a plate that is mounted to the top of the transmission housing.
Jan 27, 2014 | Aprilia Pegaso 650 i.e Motorcycles
Fuel gauge wiring diagram
how to wire fuel guage on massey ferguson 165
Jan 11, 2014 | 1998 Dodge Neon
Connecting Alternator correctly
big wire to large terminal field to field ground to ground.
Aug 04, 2012 | Cars & Trucks
Massey fergason temp gauge diagram
Really is simple, wire comes from sender and connects at gauge. Some older tractors did not have gauges and even the holes for them had to be cut out of the dash face. Sensor wires were bimetal conduits and just transferred heat from motor to dash.
Jan 02, 2012 | RTO Massey-Ferguson Tractor TE20, TO20,...
50 HP 4WD Tractor w/ Front-End Loader & Agricultural Tires Logo
42 people viewed this question
Top 50 HP Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a 50 HP Sport and Outdoor - Other Expert? Answer questions, earn points and help others
