SOURCE: my phone receive calls but it wont let me make a call
Sounds like a firewall or ACL.
while offhook, press the "?" 2 x, see if there the phone is sending packets or go to the network settings and get the IP Address.
You could try to reset the phone to factory.
http://cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a00800941bb.shtml
SOURCE: nokia 3110c call timer
Hi.
Your phone model doesn't support that option but u can realize the time after the call ends by activating that Summary after call option follow this instruction to activate it.
Menu>Settings>Call>Summary after Call>ON.
Please make sure rating this Post.
SOURCE: I cannot use my phones since Saturday. The phone message on hand
there is a loop coming from handset 1 causing the line to be busy on incoming calls.try removing the battery pack on this handset.i hope this helps
SOURCE: Stop ringing at certian phones when outside calls come in.
http://dstech1.com/programming-line-ringing/
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered
by the receptionist first, set the lines at the receptionist's
extension to Immediate Ring and the lines at the users' extensions to
No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring
directly at users' extensions -with the receptionist providing backup
-set the line at the users' extensions to Immediate Ring. Then set the
line (or lines) at the receptionist's extension to Delayed Ring. An
incoming call that is not answered by a user within 20 seconds will
also ring at the receptionist's extension.
Programming
To change the way outside lines or pools ring at an extension:
SOURCE: Error message "Number FDN restricted"
I can receive the call from outsider but wont be able to make call to outsider. When I trying to dial out to somebody it says "number FDN restricted" Please help.
liteblue usps gov provide Password reset option for liteblue account
Not enough info to help. Is there a dial tone?
ipfinder.io Free IP Geolocation API
and Accurate GeoIP Lookup Location Database provide country, city, latitude, longitude, time zone, current time, state FirewallIP Finder offers one of the leading IP to geolocation APIs and global IP database services worldwide IP Finder
