Question about Janome Sewing Machines
WHERE CAN i BUY A Bobbin Winder, Janome #801503005
    Top Expert:
  • Janome Master
  • 63,108 Answers
PERHAPS AT A SHOP THAT SELLS JANOME MACHINES
Posted on Apr 10, 2019
SOURCE:
SOURCE: Bobbin Winder won't release
i have a husqvarna rose, i has the same problem when i started using my machine. i was suggested to not wind the bobbin so fast. the reason it gets stuck is because the thread is so tight on the bobbin it actually makes the bobbin a tiny bit smaller, making it hard to get off again. if you dont wind it so fast, it doesn't get so tight.
kylee
Posted on Mar 25, 2008
SOURCE: Janome sewing machine bobbin winder
I had that problem the first time I tried to wind a bobbin. What a mess. The next time I let the thread run through my finger and thumb before reaching the bobbin. I had to do the same on a previous Kenmore.
I've also found that the heavier Bernina bobbins don't 'jump' around.
  • 14 Answers
SOURCE: bobbin doesn't fill in bobbin winder
The bobbin winder question is a frequent one and it is very easy to solve. If you look at the shaft where the bobbin sits on the bobbin winder, you will notice that it has a slot in the middle of the shaft, an opening if you will. This is where you use a flat screw driver and open that space more to give more friction to the bobbin so it is not loose on the shaft. That slot was made for that. There are different bobbins on the market so thats why the slot is there. If it is too tight, grab a pair of pliers and close the gap. The metal of the bobbin winder on that shaft is malleable exactly for this reason. No need to put plastic bag material or anything like that. Use it as it was intended for.
Posted on Jul 08, 2008
  • 323 Answers
SOURCE: Bobbin winding message
Under the top cover, on the right hand side where the bobbin winder is, there is a small switch which is activated when the bobbin is being wound. You will need to remove the cover and reposition the switch (it's located towards the front of the machine) to make it work properly.
sewman7
Posted on Nov 25, 2008
SOURCE: i have been given a
HI Vera,
I just picked up a 4613 and had the same confusion. The answer is...the bobbin winder is built in!! What you do is leave the machine threaded as normal and simply slide open the bobbin cover about an inch. You will see an arrow on the cover which you line up with an arrow on the machine bed. In this position, push the presser foot and run the machine and the bobbin will wind itself. It's actually really nice as you don't ever need to unthread the machine.
Posted on Sep 25, 2011
Janome excel 5018 decor needle goes up and down when I'm trying to fill the bobbin
Usually, the needle bar moving means that the bobbin winder spindle (with the bobbin) wasn't moved all the way to the right. If you moved the spindle, then there may be a damaged part inside the sewing machine below the spindle. (The spindle may not be engaging the winding mechanism which stops the needle bar.) I've found the bobbin winder is still available at one parts store: https://www.sewingpartsonline.com/bobbin-winder-janome-653508015.aspx . However, there may be other damage inside the machine that could be involved.
See https://www.manualslib.com/manual/994905/Janome-Decor-Excel-5018.html?page=24#manual for the pictures of moving the bobbin winding spindle.
I hope this helps.
Aug 24, 2018 | Janome Sewing Machines
How do I replace a broken bobbin winder on janome JP760?
For ~$30, you can buy a standalone bobbin winder (Sidewinder) at JoAnn's or from Amazon. Great little accessory as multiple bobbins can be wound without unthreading the machine, plus it saves wear and tear on the machine.
Jan 01, 2018 | Janome Sewing Machines
Bobbin winder not winding cotton on spool a part has fallen in side machine how do l take casing off Janome 480 quilter thank you
Am unable to help with your machine but you can purchase a stand-alone bobbin winder called Sidewinder for about $30. Just be sure to verify that your machine bobbins will work on it. The one I have will use either a power cord or batteries. Great little machine because it saves wear-n-tear on the machine plus you can wind bobbins without unthreading the machine.
Customer Reviews Simplicity SideWinder Bobbin Winder Walmart com
Simplicity Sidewinder Portable Bobbin Winder
Amazon com Simplicity SideWinder Portable Bobbin Winder
Jun 05, 2017 | Janome Sewing Machines
Can I fix a broken bobbin winder on my Janome sewing machine by myself?
If your bobbin winder is malfunctioning and you are unable to resolve the issue, for ~$25 you can purchase a stand-alone bobbin winder at the local fabric store (JoAnns or Hancocks) or even online (Amazon).
Oct 30, 2015 | Janome Sewing Machines
Where can I get a bobbin winder for my Janome JD1722 as it is broken
you can buy a separate bobbin winder at Joanne fabric stores they will wind bobbins for all machines
Feb 02, 2015 | Janome Sewing Machines
Bobbin winder not spinning
I think you have to flip a switch , watch the screen for instructions and then step on the foot control.
Jan 22, 2014 | Janome Sewing Machines
Need to know how to thread bobbin
manuals can be purchased @ janome. com. your machine should have a bobbin winder. Set empty bobbin on the bobbin winder pin. Thread spool of thread though guide(or tension wheel on the top of the machine;NOT the stitching tension.) wrap thread around bobbin to start, and push bobbin toward the flywheel. slowly press foot pedal and bobbin should begin to turn. apply more pressure to foot pedal to increase speed.When full, bobbin winder should kick back to stop.
May 29, 2010 | Janome 2049LX Mechanical Sewing Machine
Bobbin is not filling. It barely turns.
This happened on my Janome 10000...it had to be repaired in a shop.
Jun 07, 2009 | Janome Memory Craft 5700
Sewing Machines Logo
27 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
