Can I hook up my turntable to this pa amp ? it's a europower pmh8805 behringer.
  • Audio Player... Master
  • 3,903 Answers
You an do hat, but it will work. There is no phono input on unit.You can buy a stand alone phono preamp and raise to line level, and use line input.
Posted on Apr 08, 2019
SOURCE:
  • 43 Answers
SOURCE: behringer europower pmx2000 manual
I found it here.
http://www.bbmusic.bc.ca/behringer/PMX2000_medium.pdf
Posted on Apr 07, 2008
hmerchant110
  • 7191 Answers
SOURCE: I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Posted on Jan 15, 2010
funkyparrot
  • 5 Answers
SOURCE: i hooked up my new stanton t-60 turntable to an
Are you using the phono input on the Sony? If so, you're getting too much gain, you've already got a phono pre amp in the Behringer. Try using the tape or C.D. input. That should solve it.
Posted on Jan 17, 2010
  • 5603 Answers
SOURCE: behringer pmp2000 europower no sound
Probably the power amp has arced and popped a lot of components.
When teh amps go usually the final pwer transistors, their drivers and sometimes even the power supply gets zapped.
Check the output of the preamp at the inserts for the final amp with headphones to see if anything is coming through.
Posted on Jun 25, 2010
  • 5603 Answers
SOURCE: i need the diagram of
Here:
http://elektrotanya.com/behringer_pmh1000.pdf/download.html
Scroll down to "get manual" and click on it to download. Ignore other download links for viewers on the page.
Posted on Jul 12, 2011
Testimonial: "thanks alot.hope that i can help you some time"
Behringer amp 240 to 120 volts
What you may need is a
Voltage converter ' Voltage Transformer ' step up and step down ...
Connect the 220V line output to EP2500
And the 110V input to your 110V convenient outlet
Aug 20, 2012 | Behringer EUROPOWER EP2500 Amplifier
Speaker connections
Hello
Get into these links for details.
www.behringer.com/assets/EP2000_P0A38_M_EN.pdf
www.americanmusical.com/.../Manual/beh_EP2000_ep4000_manual
www.retrevo.com
Feb 02, 2012 | Behringer EuroPower EP2000 2Channel...
I need a service manual with a circuit diagramme to repair one of these with an input circuit fault.
GO ONLINE AND CHECK BEHRINGER EUROPOWER EXP3000 STEREO POWER AMP. YOU MAY GET SOME HELP THERE.
Mar 23, 2011 | Behringer EUROPOWER EPX3000 Stereo Power...
I just both the Europower pmp6000 powerd mixer and Eurolive b215xl speakers and i need help conecting the speaker to the mixer. I will be using it with some mics at a function in an hotel. How do I connect...
use 1/4 inch speaker cables. hook one speaker up to "main 1 R" out and the other to "main 1 L" out. if you have additional main speakers, hook them up the the "main 2" outputs.
look for the "bridge amp mode" switch and move it to the "main L- main R" position.
Nov 06, 2010 | Behringer Europower Pmp5000 Powered Mixer...
What wattage speakers do I use with europower ep2500
Wow thats a serious system you have there.God help the neighbours!Anyway here is an example.you need a pretty serious speaker.At 8ohms,you would need something like a 8ohm 450watt speaker system.Anything smaller will stress your amp if you turn it up.The amp would kill smaller speakers or the amp internals(channels)at higher volume.It would be like hooking up a garden hose to a fire hydrant.Something would have to give.hope this helps and happy listening
Oct 18, 2010 | Behringer EUROPOWER EP2500 Amplifier
Is this for a car?
No, this amp is for dj or live pa application.
Oct 05, 2010 | Behringer EUROPOWER EP2500 Amplifier
I hooked up my new stanton t-60 turntable to an older sony amp that does not have a phono jack. i used a behringer pp400 preamp to connect the turntable to the amp. the sound is coming through with heavy...
Jan 16, 2010 | Stanton STR8-60 Turntable
Can this all be hooked up?
There was never anything mentioned about the 18 yamaha sub in the hook up process
Aug 17, 2009 | Crown CE1000 2-Channel Amplifier
Behringer pmp2000 europower no sound
Jan 28, 2009 | Behringer EUROPOWER EP2500 Amplifier
 Grubhead
Grubhead
Marvin
Marvin
