Question about Photography
How to load film and reset panel - Photography
  • Photography Master
  • 5,950 Answers
I'm sure you think you know what you mean - care to give the rest of us a clue ? Make and model of camera, at the very least, please.
Posted on Apr 11, 2019
SOURCE:
Film not going through camera
E indicates empty.
try resetting the camera. Pus both the rewind buttons (plus/minus button by release button and bracket button on side of mirror box). Push them at the same time. Let the camera run until it stops (just a few seconds). This resets the camera. Then try loading the film again. Make sure the leading edge of the film isn't bent and is the edge is within the red rectangle under the take up spool. It should then load the film. Note: the N75 pulls all the film out of the cassette and then rewinds it back I one shot at a time until you reach '0'.
Aug 12, 2014 | Nikon N75 35mm SLR Camera
My Nikon N75 says error and there is a flashing circle with a dot in the middle when i look through the lens.... What does this mean?!
If the LCD panel shows "E" then the film isn't loaded properly. If the LCD panel shows "ERR" and "E" blinking, then the film is not correctly advanced. If the LCD panel shows a blinking "E" when the exposure meter is turned on, then film remains in the camera after it has been rewound. In all cases, reload film.
If it's not one of those cases, or if the problem persists, please reply to this post giving further details.
Feb 06, 2011 | Nikon N75 35mm SLR Camera
When film loaded it is not rolling on properly
film not advancing? film not rewinding? film transport motor dead/ needs replaced.
Rewinding but counter not resetting and light meter dead? Prolly bad connector or ic inside camera = repair shop.
Oct 16, 2009 | Photography
Cannot load the film
Check the battery. Sounds like your camera doesn't have enough power to operate the film advance function.
Apr 10, 2017 | Contax AX 35mm SLR Camera
Loading the N8008 camera
1. Set the film speed manually or DX to do it automatically by holding down the ISO button and turning the command dial.
2. Slide the camera back lock releases toward each other to open the back.
3. Insert the film cartridge on the left.
4. Pull film leader over to the red index mark on the right.
5. Close the back, making sure there's no slack in the film, and the lock releases snapped close.
6. Lightly press the shutter button. The film icon will appear in the LCD panel.
7. Fully depress the shutter button to automatically advance film to frame 1.
You can download a manual from http://www.butkus.org/chinon/nikon.htm
Mar 23, 2009 | Nikon N8008 AF 35mm SLR Camera
Stuck remaining exposure count despite new film, new film unlded
You might try closing the film compartment without film in it and press the manual rewind button. This might reset the counter circuit.
Dec 08, 2008 | Kodak Advantix 2100 Auto APS Point and...
I cant seem to load film in my camera . it winds it back up as soon as i close it or try to take pictures
It's still in auto-rewind mode. Depending on the model, do a manual rewind with no film in the camera to reset the internal counter. Then load film and try it. Please leave feedback if this helps.
Jul 26, 2008 | Cameras
Camera wont accept any film?
1.The film leader should be placed correctly.
2. the ASA detecting pins in the film champers should be clean.
3. Check for any buttons being in pressed conditions.
4.See whether the frame counter resets when opening the door
5.Then try with a mechanic.
Mar 26, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Photography Logo
Top Photography Experts
Steve Allison
Steve Allison
Ric Donato
Are you a Photography Expert? Answer questions, earn points and help others
