SOURCE: Four blinking red lights.
you can have the inverter board replaced...instead of the entire panel.
KDL 40S2010: inverter part # 178950032, you will also need 2 spacers..part # 289765511
you're looking @ 200-300$ for the inverter and 5-10$ a piece for the spacers.
KDL-46V2500: inverter part # A1251295B
you're looking @ around 500-600 $ for the part
SOURCE: TV won't turn on, red flashing light
Hold The Off Button for 20 sec should make clicking noise switch off at power and on again should be working
SOURCE: light flashing 13 times on sony bravia KDL-46x3100
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
SOURCE: problem using headphones 3.5mm output with Sony Bravia tv
Sony Bravia Model No.KLV-32BX300 LCD TV is with me but i cannot take the audio out from the TV. I undertand that there's an audio output which I don't understand. This may sound a bit stupid that a tv does not have audio out but yes it is! I tried to google about this and no one seems to be able to fix this. So anyone here has encountered this problem before or using the same model and has solved the problem? I seriously wanna connect my speaker to the tv as I'm connecting to my Home theatre system
SOURCE: Sony Bravia KLV-40S200A LCD TV standby indicator blinks 5 times
Here is a link to the service manual--
http://www.scribd.com/doc/46056922/KLV-23S200A-and-Other
Page 11 explains the error codes--unless you are a tech with a meter etc it will be a shop repair.
A lot of good info including taking set apart correctly.
"abnormal power"
SD TECH
