Contributor
- Posted on Apr 22, 2023
Re: MItutoyo sj-210 surf tester keeps saying limit error....
After showing limit error watch its interface top side area. If it showing red marked area on the top after putting the drive unit to the surface then You need to change the detector.
Did you ever get a response to this? I'm having the same issue, but the troubleshooting guide in the user's manual does not list "limit error" as one the issues. For me, after the limit error message clears, I have no problem getting a good reading on a reference standard. If I try to take another reading, however, I get a limit error. When it clears, again, I can take one reading, then the next produces another limit error. No obvious reason or remedy.
Turn the battery switch to on and unplug. hold down power and start/stop button simultaneously. This will start the homing process. Its in the manual on chapter 15-3 "retracting the detector" do not use a probe extension as this could interfere with the process and ruin your detector
Trying to do the homing process, but It just keeps saying Escaping and does not fix the limit error issue. Any thoughts?
after showing limit error watch its interface top side area. If it showing red marked area on the top after putting the drive unit to the surface then You need to change the detector.
