SOURCE: is there a simple way to slow the speed down on a
On the motor where the clutch is you will see thge large pin with a nut on it, as you press on the pedal the pin engages with the motor, if you loosen the nut and unscrew the pin bit by bit and try the machine you will get to a point where you will have absolute control on the speed.
SOURCE: Hello-- I am sewing on
hi there
firist make sure you are use throat plat with big hole if you are use big needle size like 18# or 21#?
second check timming between needle and hook ok or no ?
thired check the blade point of hook toutch needle strong or just light touch?
finally which model you are used? DDL8700-A or DDL8700-H?
best regards
ashraf abozid
[email protected]
Testimonial: "i had solved the problem but these are the right steps to take. thanks. jenae"
SOURCE: The top thread is looping every 30 or 40 stitches
hi there
please check bobin case spring maybe need t adjust or rplace.
please check if you are wind bobin by correct way not too much titght or not too much loose. thread insaid bobin must be littel soft.
the last reason maybe the tip of stoper for hook id damaged and need to rplace.
best regards
ashraf abozid
[email protected]
SOURCE: Does The Juki 8700 sewing machine have a automatic Thread Triimmer
final answer about this questionhello all
in case of normal machine you need to add many parts to convert from manual to auto thread trimmer ( need electronic motor with control - auto thread trimmer mechanic components - hook - feed dog - etc.... ) it's very difficult to change from normal to auto thread trimmer.
best regards
ashraf abozid
try changing the needle to one that will work with heavier thread
you may have to change the bobbin to heavier thread also
try adjusting the tension also
