SOURCE: Cannot reverse door on Electrolux fridge freezer
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
SOURCE: ELectrolux frontloader EWF1090 door wont open
Make sure you drain the machine first by setting a spin cycle manually and see if it releases the door after a few minutes. If that fails then switch off the machine and leave for 5 mins, door should release but you could end up with water on the floor. After this clean your filter and check you water pump, then try a short cycle without clothes.
SOURCE: electrolux model ewn14991 door wont open even
http://www.fixya.com/support/browse/washing_machines
Hi
I find that patience is of the essence while waiting to be able to open the door.
Check that there is no wetness that almost functions like glue.
