company has down load manual, chronos pull out stem all the way and press the right top or bottom button , it should move in sec. incruments .,. press all way to the 12:00 and push in stem. press chro run top right. stop it after 10 sec. top right. then press bottom right. to reset it should go to 12. .. other dials can be set by stem in middle position.
Try the following, which I discovered by accident on my Tag Professional.
Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions.
Hope this works for you.
Geoff
Easier than you think. Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
pul crown all they way out
press top right button to set the minute hand
& bottom right button to set the hour
if not work then puch back crown to 1st click and do it same function ,, if still not working then pull crown again and push and hold both button for 5 sec. its reset ,, and try to adjust it again by pressing top & bottom button
hope that will help if not and you are in chicago
bring it to us
at
Amfix Jewelry & Watch Repair
203 N. LaSalle St
Chicago, IL 60601
312 641 7000
