Parts manual
http://www.hobart.co.kr/data_file/3A200Q595.pdf
owners manual
https://www.manualslib.com/manual/1335037/Hobart-A200.html#manual
video below which may help
https://www.youtube.com/watch?v=ceQE8PEYPPI
https://www.youtube.com/watch?v=XaeWrSEmP9I
https://www.youtube.com/watch?v=CkLWY9aKLdY
SOURCE: Hobart A200
amy, depending on how old your mixer is there are 2 types of clutches for 1st gear.these could be your problems--a key is sheared on the shaft--shaft/gear is broken.the bottom part of the mixer where you put on the attachements is called the planetary,does it look like it has moved down?you could tell if the dough hook,wire whip,ect,ect is hitting the bottom of the bowl.if this is the case its just simply tightening the 2 nuts next to the beater shaft.if this is not the case you would have to dissasemble the transmission.let me know.
SOURCE: A200 problem
Check the planetary.this is the bottom part of the mixer where you attach the hook.
You will see two nuts; make sure their tight as the planetary may have moved down.
Also have a look below:
http://cgi.ebay.com/HOBART-A200-20-QUART-MIXER-SERVICE-PARTS-MANUAL_W0QQitemZ160203114233QQcmdZViewItem
SOURCE: Hobart A200 Mixer not working
Sundance,
Please visit the corp website www.hobartcorp.com and click on the "Sign In" link in the upper right hand corner. You'll need to complete a brief registration form, but then you'll land in the Hobart Resource Center.
Hobart no longer manufactures the A200 mixer - but you can review and download a user manual and a parts catalog from the Resource Center on your mixer. That should help you understand the parts need.
We do sell replacement parts direct to end users, just visit our service website at www.hobartservice.com - and click on the "Locate on Office" link. You'll be able to contact your local Service branch to purchase a replacement part OR to have them take a look at the unit and provide a quote on fixing it.
If you have additional questions on Hobart products - please contact me at [email protected] .
Thanks!
SHerri
SOURCE: Hobart A200 age and lubrication
No, do not use Shell or Chevron grease or oil.
It will damage the gears and the interior of the machine. You must use food grade grease.
If you use industrial heavy duty grease you might have trouble with the local Code Enforcement ( if this machine is used in a restaurant or bakery )
depending on your state's rules, laws.
Here is a website for the grease:
http://www.foodprocessing.com/vendors/products/2008/039.html
You might want to check out my website too:
http://www.jgbakeryequipmentrepair.com/
About the age, hmm.. sorry but no i don't know anything.
