Home Logo
Mabel Ladbrook Posted on Apr 08, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ok have a single wired smoke alarm on celing with 9v battery we have changed battery and pushed the test button but it keeps beeping ( live in Sydney)
Charles Houlroyd
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 124 Answers
  • Posted on May 19, 2019
Charles Houlroyd
Expert
Level 2:
New Friend:
Cheetah:
Answers
124
Questions
0
Helped
65153
Points
268
If you have changed the battery in your chirping smoke detector and it still chirps, you might think your detector is bad. ... With the battery removed, press and hold the test button for 15-20 seconds. Replace the new battery in the detector and plug in the power supply. Restore power to the circuit breaker.
5 Related Answers
Anonymous
  • 1959 Answers
  • Posted on May 23, 2009
SOURCE: smoke alarm beeping
If after replacing the battery the alarm is still beeping, the smoke alarm is bad and needs to be replaced. Hope this answers your question. Best of luck!
Greg
Anonymous
  • 36 Answers
  • Posted on Sep 28, 2009
SOURCE: kidde nighthawk Carbon Monoxide & Smoke Alarm single beeps
If detector is more then 5 years old it will beep every 30 seconde to wirn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Anonymous
  • Posted on Jan 20, 2010
SOURCE: My alarm and smoke detector keeps beeping a single
Ours keeps chirping even after we replaced the battery. I'm not sure how to fix it.
We are going to try and clean it but if it keeps doing it after that then I guess it means it needs to be replaced, right?
Anonymous
  • 90 Answers
  • Posted on Apr 23, 2010
SOURCE: Smoke alarm keeps bleeping
Here are the steps:
Was this always like this? If not, change the batteries, clean it up. Consult the local fire dept. The help for free.
If that does not work, you will need to get it serviced/repaired.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Anonymous
  • 74 Answers
  • Posted on Sep 05, 2010
SOURCE: Cannot open alarm system to change battery
Push down on the tab at the top of the panel and open the front panel (Panel will say enter security code now). Put a slotted screwdriver in the top hole and depress to fold dowm the second door. Battery is inside the plastic case with two screws holding on the lid. The battery is a 6V 1.2AH battery
AlarmProfessor.com
1helpful
Kiddle smoke and carbon monoxide alarm that talks 3 of them one ine bed room one in kitchen. Last in basement wired.
All smoke detectors have a 9v battery in them. Try swapping the battery to see if it clears the beeping.
1helpful
HOW DO I REPLACE BATTERY ON FIREX FX1218
BATTERY REPLACEMENT Always turn off power to smoke alarm before replacing battery.
Replace battery at least once a year, or immediately when the low
battery signal sounds (a beep once per minute indicates low bat-
tery). Batteries should be replaced regularly as necessary, even
when the smoke alarm is receiving AC power.
Use only the following batteries as replacements in this smoke alarm: Eveready 216, 522, 1222, Duracell MN 1604, or Ultralife U9VL-J [Alkaline batteries 9Volt] DO NOT USE RECHARGEABLE
BATTERIES.
1. Turn off power to smoke alarm at main service panel.
2. Turn smoke alarm counter-clockwise to detach from mounting plate.
3. Gently pull down smoke alarm. Be careful not to separate wire
connections.
4. Pull out power plug from back of smoke alarm.
5. From back of smoke alarm, lift tab to open battery pocket door.
6. Remove battery from pocket. Disconnect and discard bad battery from battery connector.
7. Connect a fresh, 9-volt battery to connector. The battery will fit
only one way. Be sure battery connector is securely attached to
battery terminals.
8. Place battery into battery pocket.
9. Close battery pocket door. Push down until it snaps into place.
10. Replace connector plug. Connector will "snap" into place.
Gently tug connector to be sure it is attached properly.
11. Reattach smoke alarm to mounting plate by turning smoke
alarm clockwise until it snaps into plate.
12. Turn on power and test smoke alarm using Push-to-Test button
Jan 03, 2018 • Home
Why does my smoke alarms not all go off when I push test button?
I am assuming that your detectors are interconnected to all sound at the same time.
Pushing the test button is not the same electrically as an alarm activation.
The Kiddie manual does not mention the sequence of operations when the test button is pressed. You may want to contact Kiddie to find out if this is ok.
You can also test your detector with smoke to see if they all sound like they are supposed to.
Open brooks smoke alarm to change battery
Hi Robin
Usually push in (up) & turn
Feel it as you turn
.....then remove from other half.
Have 9v battery handy for replacement.
Why does My alarm still beep after battery is replaced
Could be a bad or used battery. ry replacing it with one that you tested to make sure it has 9V. Also make sure the activator arm that's held in place by the battery body is properly seated and not broken off. If all is OK, and still not working replace the unit.
Aug 08, 2014 • Home
My alarm is testing multiple times a day
Check that the battery is installed the right way around. Most smoke alarms can only be tested manually (by pushing the button). If you are hearing a single beep every 50 or 60 seconds then this is the low battery indicator and this will sound if the battery is inserted the wrong way around. If the siren is actually sounding continually then your smoke alarm might be clogged with dust or other foreign matter. All smoke alarms should be replaced every 5 to 7 years as the components in them only have a limited life span.
3helpful
Our hard wire smoke detector model i12060 just beeped really lound a few times and stopped, it glows green and flashes red every few minutes?
Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
2answers
Hi friend has a fisher and paykel refridgeator and its sounding an alarm of one beep and then 3 or 4 long beep followed by a short beeps then then a single beep its a top freezer model and the refrigeator...
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Hello I have a KIDDE FYRNETICE smoke alarm.
According to the Kidde website, this unit was discontinued in 2010. If the unit is more than 10 years old it must be replaced per NFPA 72 (assuming you live in the US)
2helpful
2answers
My alarm and smoke detector keeps beeping a single beep every few minutes
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
