SOURCE: NEC DTERM SERIESI
You may be right about it coming from another extension! If that is the case you need to return the message by pressing the key, finding out what extension is ringing and answer the phone otherwise the message will never be returned and the message light will stay on.
Quite an annoying feature with many phone systems. Nobody ever uses the feature and people have no idea what's happening when someone else accidentally presses the wrong key at the wrong time.
SOURCE: NEC dterm series II phones-name desplay
This works on the series E phones. It may or may not work on the series II.
Pressing the TRANSFER key will change the current letter to lower case.
Example to enter the name “Pat” press:
77 HOLD 22 TRANSFER HOLD 88 TRANSFER HOLD
SOURCE: NEC Dterm 80 LCD display is defective.
The common thing on this style of phone is the silver ribbon cable that connects the display to the main circuit board comes loose after being dropped or knocked around and needs to be reinserted. You will need to open up the phone to do this. If this is not the solution then you will either need to purchase a used phone, send it in for repair or use another phone to take parts from.
NEC Dterm 80 phone, 1 ext. is blinking and we can't get it to turn off. It shows a busy signal when you try to call it.
Help it is the owners phone!!!
