Here are two sites that may help you/
https://www.youtube.com/watch?v=-MS5YNUlMHQ
Free User Manuals and Owners Guides ManualsOnline com
SOURCE: need a point setting for ao smith air compressor ac motor
There is not a point setting for air compressors. The pressure switch can be adjusted. Remove the cover from the pressure switch. Adjust the nut tighter for a higher cut off pressure or looser for a lower cut off pressure. It sounds like the compressor is trying tostart under load. If the unloader valve is not working, the compressor will draw excess amperage and do what you describe. The unloader valve releases the pressure in the cylinder at the end of the run cycle so the compressor can start the next run cycle under no load.
SOURCE: ive been searching for a
not really sure but try contacting these folks
This is the only link i could find
http://nobel-ae.com/Nobel/ShowProduct.asp?cid=5
Lutfi Trading (LLC)
PO Box :
1430,
Dubai, UAE.
Tel : +971 4 2225335,
Fax : +971 4
2228823
Email Us On:
Sales : [email protected]
Please Click here
for all queries and enquires
SOURCE: I need a manual for a Smith Corona Model NA3HH
Google Will Repair in dunkirk NY they may be able to help.
DickyO
Disappointed no real instruction on use of the oven. Doesn't help when you Google for a manual and site isn't accessable. It also said I had one posted to me on 8/4/22 and I definitely don't have it. How they would have my address is beyond me.
