I heard a rubbing sound on the last cpl. loads and can see a build up of lint through the vent holes in the rear of the drum. There are 3 torx head screws in the center but I'm not sure I should loosen them without disassembling the dryer cover. How do I access this area to clean it? How do I remove the case panels? I can't locate any info on this model. Purchased it at Lowes in 2013. Thanks.
SOURCE: How easy to access the 3 screws?
Underneath. Don't see original post here, but to replace a pump (actually, just the pump motor) on an LG front load washer: Drain water out of small hose inside recess and remove access door cover (at lower left of machine). Remove one phillips head screw and use a plastic putty knife or similar tool to push in on left or right side of recess to remove the plastic recess cup. Now remove the two other phillips head screws visible. Tilt machine back and access pump Assembly from under machine. There is a tab that you will have to work loose. Disconnect electrical wires from pump at disconnect plug. You probably want to remove the hoses going to and away from the pump (squeeze clamps). Pump motor is easy to change out now with three more phillips head screws.
SOURCE: how do you remove the
Welcome...
You need to look up near the top of the cabinet front, there are screws way up near the top on each side that secure the front panel to the cabinet. Take them out and tip the front forward and then pull up. be careful of the door switch wires.
if you need a comprehensive service manual for that dryer, it can be found here:
http://www.fisherpaykelparts.net/ecart/category.php?category_id=53
SOURCE: i need to replace drum belt in whirlpool ggw9200lw
Watch the video, it will help you see how.
http://www.youtube.com/watch?v=9dd1Ac4_pXY
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Dryer 3 cycles to dry a load , lint build up around heating elem
try cleaning ur exhaust vent u may have lint in it an this is causing ur dryer to overheat an kill the flame on the burner......this could be the reason u dont have heat because it shuts off as soon as it fires up
SOURCE: Frigidaire FEQ332 dryer: I (stupidly) removed the
well first turn the power off without those screws there is a chance you can arc the drum out agianst the element second you have to get at least one screw back in then rotate the drum slowly to line up the other holes do not run without the screws can cause some major damage
Testimonial: "Swift and helpful response - many thanks!"
