Model 21fx
SOURCE: LG vertical failiure vertical line at the bottom of the crt
replace the vertical driver ic and the proccesor ic
SOURCE: Lg 21inch CRT TV automatically go to stand by
The protection circuit is preventing it from starting because there is a problem with one of the internal scan circuits, either the line-scan unit or frame-scan unit. There will either be a dry soldered joint or a component has failed. It could also be a power supply fault but that is not as likely.
SOURCE: Vertical ic used in lg crt tv model no 21FE3RG-AX
If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand TVs and other devices are given.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
SOURCE: Lg crt tv model 32fs4rmb only picture no sound I changed d sound ic but still same problem
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Chang with an other IC. Continue this process; till you get sound.
