I have a tear in my treadmill belt about 4 inches long. it it possible to repair it or does it need to be replaced?
The first question is whether the tear is inline with the belt rotation or across it. The second question is how the particular make of treadmill you have controls belt tracking.
In general, the "right" answer to this question is to replace, rather than attempt to repair, the belt. You will need to carefully patch the back side of the belt with at least a couple of inches' overlap on all sides, carefully keeping the tear aligned as you do so, and then ensure that the material you used will not damage the deck or rollers, or stretch or start to come loose or fold over as the belt flexes and friction heat develops during running.
Many treadmills use lateral tension in the belt to keep it centered during operation (one or both rollers are gently tapered to be thinner at the ends). Any loss of lateral tension integrity will cause the belt to continue to be separated as it passes over these, perhaps widening or distorting the area of the tear or contributing to belt misalignment or 'walkoff' -- something that the usual dodge of blocking the treadmill slightly on one side won't help.
SOURCE: Torn Serpentine Belt. Bad belt driver
You say belt driver? The belt runs on a series of pullys, there should be a pic./diagram on the radiator support that shows the routing of the belt. simply take the belt off and check each pully( they will either drive the belt or be idlers/tension pullys)to see which one has any "side to side" motion. If it is on a "driver" you are looking at replacing that part(water pump,power steering pump. etc.), as the real problem will be a bad bearing in that unit.
SOURCE: small rip in treadmill belt
Yes you can repair a treadmill walking belt. I used a specialty glue that is flexible and super strong. It is used in aeronautical applications so is very strong and importantly flexible. A new belt repair kit on Amazon and Shopify comes with belt patches. The rubber anhydrous adhesive and tapered edges of the patch work well and like a broken bone make the belt stronger than the original. If the belt is completely worn then this will not work. If there is a rip or hole that is localized then a patch works great and avoids the need to replace the entire belt. BTW I have replaced entire belts on several treadmills and it is not for the faint hearted. Many times the new belt either does not fit or the treadmill components that need to be removed break, screws get stripped and plastic components break. Huge job. Fast and inexpensive.
Email me if you need more information [email protected]
Although most home treadmills are designed for easy operation, there are some common problems that are inevitable. The console may not display. Perhaps a loose or slipping running belt poses a safety hazard. Maybe the treadmill runs at an unpredictable speed. Those are just some of the things that can happen to bring your workout to a halt. While certain repairs will require the services of a professional who specializes in treadmill maintenance and repair, there are some basic repairs that you can do yourself.
Difficulty:
Moderate
Instructions
1.
Clean and routinely maintain the running belt. The belt may be worn if the treadmill stops operating or trips the circuit breaker. Look for any tears in the belt. Test the belt by putting the treadmill at full incline. If it does not shut off, you may need to replace the belt. You can try lubricating it first, but the safest fix is simply to replace it.
Tighten the running belt if it is loose. A belt can slip if there is too much friction. Be careful not to tighten the belt too much, though. You should be able to lift the belt at least 3 inches.
Push the belt in the direction that it normally turns. Turn off the power before you start. If the belt is difficult to turn, there is high belt/deck friction. However, if the belt moves freely, that's not the problem.
Examine the roller sleeve to see if it is centered on the running belt. If not, this could cause the belt to move to one side. Often a common problem with treadmills, you can try making adjustments yourself, but eventually you may need to replace the sleeve or roller.
Stop the treadmill and immediately unplug the power cord from the outlet if you notice a burning smell. Overheating could be a sign that there is too much friction or a short in the wiring. Examine the belt and deck for any signs of wearing. If they check out alright, inspect the wiring. Replace any damaged parts as needed.
Check to make sure that the power switch is on if you suddenly lose power. If this isn't the cause of the power loss, unplug the treadmill from the wall outlet and individually test the fuses, breakers and switches. Test the wall outlet first, as a fuse may have blown or a circuit breaker tripped.
Allow the treadmill to run at a speed of 2.5 mph without anyone walking on it if you notice fluctuations in the speed. The speed should be constant. If not, there could be a problem with the motor.
Test the motor using a fully charged lantern battery. The motor should still operate at slow speed.
Replace the batteries in the panel if it dims. If the batteries aren
