Televison & Video Logo
Pat Gardner Posted on Apr 07, 2019
Have a GPX kcll88060T no picture HELP!
Have sound but no picture I have a black screen no color no nothing only sound. I do have the remote that came with the t v Tell me what to do cuz I have had this happen before and I forgot what I did, just playing with remote I got picture back on! Plese help!
5 Related Answers
Anonymous
  • 73 Answers
  • Posted on Jul 31, 2007
SOURCE: No Picture, sound or anything during playback...
cleaning cassette may help - if the picture comes back but soon goes blue screen ? your heads need thorough cleaning or replacement ;
Anonymous
  • 17 Answers
  • Posted on Feb 11, 2008
SOURCE: No picture no sound nothing
looks like a power supply unit (PSU) issue. You can not do anything about it. I suggest you contact the service center of your supplier.
Anonymous
  • 63 Answers
  • Posted on Sep 03, 2009
SOURCE: Toshiba tv screen goes black every 5 minutes with sound still on
Is it ok when you watch regular TV thru the cable or sat?
Lilo
  • 19 Answers
  • Posted on Mar 27, 2010
SOURCE: How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Anonymous
  • 9 Answers
  • Posted on Mar 19, 2011
SOURCE: my kids lost the remote
Unfortunately, the only real answer is that GPX is such an uncommon brand that many 'universal' remotes are not compatible with it. Your best bet is to look for a replacement remote for your D200B, but they don't seem to sell replacements. You may have to settle with using buttons on the DVD player itself, or buying a new player.
1helpful
How do i fix a non responsive tv set?
Do the ballast first. That should get the picture back. The main board controls everything else.
Samsung dlp hl55679w
It sounds that the light engine has the fault. Contact the authorizes service center for Samsung.
I posted a problem on how to remove panel but I solved it. Now as I mentioned the tv comes on goes green then black no picture just sound. I followed instructions on adjusting G screw but it doesnt work...
Its possible one of two thing have occurred, you have maladjusted the G screen control on the high voltage screens and focus assembly. Turn down (counterclockwise) all three of the screen drivers. Adjust each until a light appears in the each lens, red green and blue. Go slow or lines will appear if set too high. If all three lamps stay lit after this adjustment the look at your screen with color level down to zero using your remote and the picture menu. Adjust the three color drives to get a good black and white balance appearing on the screen. Now adjust the color level from the picture menu back up to normal range.
If you still get green diagonal lines after this adjustment then I would suspect that the green lens has a heater to cathode short in the tube.
1helpful
1helpful
Audio no picture
do you get a splash screen when there is no Disc playing ( something that says something like DVD VIDEO). If not and the scren is just always black then it sounds like the backlighting circuit has failed
No picture/no clock/ no sound nothing just black screen working fine one minute/gone next
i Know that GPX had problems with their under the counter TV. Contact them and you probably need to send it back to them for replacement. or you can check your stores to see if they have one like this.
1helpful
2answers
2001 Sony KV-36FS12 black screen problem
replace ic355 part number is 8-752-098 / or a cxa2131cs is the generic part number.
regards,
daniel.
Sound works fine - there is no picture...
Your remote control has a button on it marked "TFT" (which is your LCD display). Power on your unit and hit this button on your remote - it turns power to the screen on or off. If your screen is just gray, as if it has power but not image (not black as in "dead") then you might be in the category of a different post of mine on this machine.
GPX KL858S undercounter 8.1 inch color tv has gray screen and no picture. Sound is fine.
I talked with GPX Customer Service and they offered an upgrade for a similar unit which would be hi-def and digital capable for a nominal amount, I am hoping that this problem will not repeat itself in the next tv.
2helpful
2answers
Black rectangle on screen
Try pressing the "View" button on the remote control a couple times -- it sounds like you have the picture-in-picture mode turned on but with nothing showing on the second input.
Top GPX Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
