Question about Home
How to replace the cork screw in an Alpero automatic wine opener? Great wine opener but no instuctions on replacing the screw that goes into the cork to pull it out
    Top Expert:
  • Home Master
  • 63,068 Answers
NOT MAED TO FIX SAD TO SAY BUY ANOTHER ONE
Posted on Apr 08, 2019
SOURCE:
  • 1274 Answers
SOURCE: Not functioning ! Cork screw not inserting to
Hi rich, My name is John. Welcome to FixYa. Turn the screw one turn counter clockwise while pushing inward. Thanks for choosing FixYa....John
Posted on Dec 06, 2010
SOURCE: A cork is stuck in my Oster Electric Wine Bottle
We had the same problem, and we took the thing apart, unscrewed the cork from the corkscrew and put it back together. You have to make sure you line everything up properly inside, though. There are contact points that need to be lined up on the inside.
Posted on Jun 05, 2011
  • 3 Answers
SOURCE: I have a Rubbermaid cork
....................unscrew it!..................
Posted on Jul 22, 2011
SOURCE: I have an Oster Electric
Use a screwdriver (or whatever) to push the inner ring at the opening as far inside the appliance as you can. It is a black piece with a spring action that has plastic molded ridges inside. The ridges on the inner edge of this will grasp the cork. Then, while you are holding the inner section in place as far inside as possible, push the button to operate the opener and the cork should come out as it normally should. I had half a cork stuck up there, and this just worked perfectly.
Posted on Sep 01, 2011
jim9550
  • 6 Answers
SOURCE: how can I replace a pig tail on a bottle opener
Nobody sells a replacement, unless you are using the very expensive screw pulls. They do have replacement parts.
Posted on Nov 05, 2014
My electric wine opener stopped working with a cork in it
Battery has gone flat or it has overloaded the cork screw motor and you will have to cut the old cork off. Try again once changed the battery
Sep 21, 2017 | Home
A cork is stuck in my rabbit electric wine opener.
It automatically ejects removed cork from corkscrew, if this does not happen then it is faulty and needs to be returned under warranty.
Jan 08, 2017 | Home
How can I replace a pig tail on a bottle opener
The following seems to work, but might be tough if you don't drink the wine first. http://www.youtube.com/watch?v=5Y82j3R7tXw
Jul 02, 2014 | Home
Won't pull cork out
Battery may be soft. N/G
If it goes in with No Problem and will not pull out
May 21, 2014 | Waring Pro WO50 Cordless Wine Opener
The cork is stuck in the wine opener when I was trying to release the cork after the wine was opened
I used a long tweezers -- about 1 ft long. I held the cork in place, then pressed the reversed button. It came right out.
Feb 22, 2014 | Brookstone Automatic Wine Opener
How to open wine bottel
https://www.realsimple.com/food-recipes/shopping-storing/beverages/open-bottle-wine
https://www.wikihow.com/Open-a-Bottle-of-Wine
Use a sommelier tool, ie, the one with a corkscrew, a little knife, and the 2-step lever thing.
Otherwise, a corkscrew: in both cases, cut the top off the protective covering on the top of the bottle (the foil), start the corkscrew part with some downward pressure in the center part of the cork, and turn clockwise. then use the rest of the device to leverage out the cork. In the worst case, use a screwdriver to screw in a screw into the cork, and pull the cork out with pliers.
Invest in a wine vacuum pump and store the red wine at room temp, white wine in the fridge.
.....of course, for screw tops, just unscrew the bottle as you would with soda pop.
Feb 21, 2014 | DOUGLASS HILL Brut 750ML
Cork stuck in wine opener
amazing that noone has answered this question including the people at Waring - I have no idea how to do this
Feb 18, 2014 | Waring Pro WO50 Cordless Wine Opener
How to remove cover from waring pro wo50
A broken cork was stuck up inside my Waring Pro Wine Opener. Model WO50B. No amount of maneuvering could get it out. I removed the two small screws holding the silver part of the opener on. After that was off I could see two more screws and I removed those. The unit still would not come apart. I noticed that there were four oval shaped rubber plugs up on the black part of the unit. I pried the ovals out with a wooden skewer. That exposed the other four screws holding the long part of the unit together. Once I got those out, I gently pulled the two sides apart about an inch. I could have pulled it completely apart at that point (I think) but from there I was able to free the broken cork from the big internal cork screw. Everything screwed back together fine and the unit works again.
Nov 20, 2013 | Waring Pro WO50 Cordless Wine Opener
Waring wine opener wont pull out cork
We learned that NONE of these electric wine openers like the new "plastic" corks. Take a needle nosed plyers and hold the cork tightly(as it sits inside the housing) and gently push the button to release the cork. it should work.
Apr 14, 2012 | Sunbeam Kitchen Appliances - Others
Home Logo
49 people viewed this question
Top Home Experts
Donni Steen
john h
Are you a Home Expert? Answer questions, earn points and help others
