Garden Logo
P
Peter Gibala Posted on Apr 06, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hasqvarna lth 2038 rideon, stalled, now won't crank under compression
CJ Rock
Level 3:
  • Husqvarna Master 4,417 Answers
  • Posted on Apr 07, 2019
CJ Rock
Husqvarna Master
Level 3:
Answers
4417
Questions
0
Helped
1642059
Points
14985
Likely you are experiencing starter stall due to cylinder decompression malfunction. The OEM Briggs & Stratton OHV engine requires periodic adjustment of valve lash for proper decompression when starting.
1 Related Answer
Anonymous
  • 784 Answers
  • Posted on Jan 31, 2011
SOURCE: Husqvana LTH 2038 model, blade
it sounds like whatever bent the blade may have also bent the rotator shaft,, if this is the case - replace the right hand rotator shaft,, then re-install the new blades and all should be good to go.
(( if the shaft looks ok on a roll test,, it could be the mount and metal portion of the shaft and you could get lucky and try and use a breaker bar to flex and bend it back into the proper position ).
c...
I have been given a Hasqvarna Huskylock 550D overlocker. I am in need of a copy of the manual. If anyone can Help it would be very much appreciated Thankyou
https://www.google.com/search?q=Hasqvarna+Huskylock+550D+overlocke&oq=Hasqvarna+Huskylock+550D+overlocke&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
I got hasqvarna wr125 2002 and it won't startt any ideas
Is there spark at the spark plug ? Does it have compression ? Do you know how to test for these thing's ? Is the fuel turned on ? reserve ?
Engine won't run
Cranks but won.t run, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Engine cranks but won start Troubleshooting tips
Diagnostic flowchart for car that won start or stalls Troubleshooting for...
Troubleshooting and Fixing Car that Won Start
No Start Diagnostic Basics EricTheCarGuy
Trouble staying started, then won't crank on Geo Metro 1997
old post, but others might find it useful.
sounds like you cranked the battery dead. huh?
1problem is not 2.
why it dont start is comlex.
ever check compression,
ever put in new timing belt at 60,000 miles (every)
ever tune it up, ? and for sure every 60k, per the op. guide in glove box>?
1980 Suzuki Gs450L won't start. I stalled out pretty bad in 4th gear and it won't start back up after. Bike won't even crank over, just makes a clicking noise. Any ideas?
pull the plugs then crank motor you may find one cylinder full of gas and that will keep it from cranking, if it cranks without the plugs allow it to dry for a bit , make sure plugs are dry then install and hopefully GO!
1helpful
My 2000 Dodge Grand Caravan will crank but won't start.
Hi, if an engine cranks but refuses to start, it lacks ignition, fuel or compression. When the engine cranks normally but won't start, you need to check ignition, fuel and compression. Ignition is easy enough to check with a spark tester or by positioning a plug wire near a good ground. No spark? The most likely causes would be a failed ignition module, distributor pickup or crankshaft position (CKP) sensor.
2answers
Husqvana LTH 2038 model, blade is bent so bought new ones, when i tried to put on the new ones the right hand side one hits the deck. What could it be (checked the blades they are the right ones)
Probably bent jack shaft or bearing. Or the deck bent, where the bearing is mounted. It is possible but probably just jackshaft. Or when you put the blade on it got hung on the part that go's in the center of blade and made the blade sit crooked. Thats what I do.
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
