SOURCE: Macbook Pro DVI---> HDMI + Digital Optical Out = Problem w/ Sound
On the Sony The HDMI takes "priority" over all others, that's why you loose audio. If you run your DVI/HDMI to the TV and optical to the soundbar that would fix your issue. If your TV does not have Multiple HDMI inputs, you can get a DVI/Component adapter for your MBP then run it to the TV, or, If you have to have HDMI just to have HDMI, you can get a 2:1 HDMI switch and still have optical to your soundbar. Make sense? If youneed more help, just post a comment and I'll help some more.
SOURCE: I am having problems connecting
Do you mean by "I have one bar for signal to my router" the length of the cable from the router to LG ST 600. Then you can use 3 to 4 metre cable to connect from router to ST600. About HDMI cable vertion 1.4a HDMI is necessary if you need to watch 3D content. If not you can use vertion 1.3a HDMI cable.
ok
SOURCE: LG sound bar connected to Pioneer TV by optical cable not working
1. if you have something else that you can test the optical wire on. do that first. dvd player etc... if the test item works, it's the sound bar (or a setting in the sound bar.)
2. check the audio settings on your t.v. make sure it's set to output to optical.
3. replace the wire.
if none of these solve the problem, the t.v.'s optical output may be bad.
Try out optical tv to in optical in your sound bar it will work.
Carl
SOURCE: how to connect my tv to optical outlet
What audio-outputs does your TV have? SPDIF? 3.5 millimeter stereo-jack? White/Red RCA "post-and-collar" sockets?
What inputs does the sound bar have? (Same choices as above.)
Note that you might need a 3.5mm to stereo-RCA cable.
