SOURCE: my janome sewing machine isn't locking the thread
If u r new to using sewing machines please take some ones help who knows using any machine. You obviously are not fixing correctly. It should click in right place and the machine shd be able pull the thread before u begin stitching.
SOURCE: I'm looking for sewing machine manual. The
Hi! I found a manual for your machine at http://sewingpartsonline.com/janome-newhome-sewing-machine-instruction-manuals.aspx
Hope this helps!
Robbie
SOURCE: janomes sewing machine bobbin
Hi. Check to make sure the needle is in correctly. There is a flat side on the needle shank and that has to be facing a particular way. For most modern machines, the flat side of the needle faces to the rear, away from you, but it's always a good idea to check the manual to make sure on your machine. If the needle is bent, that can cause the same thing, but it's almost always that the needle is in wrong.
Happy Sewing!
Robbie
