Question about Karcher Garden
Karcher hd3101dr alternating pressure
Karcher hd3101dr: pressure on with trigger pulled for 5 seconds pressure off for 5 seconds. Continues to alternate. I cleaned the unloaded valve but it was relatively clean when I pulled it and moved pretty easy when compressed. Any other ideas? New unloaded?
4 Suggested Answers
SOURCE:
  • 313 Answers
SOURCE: Karcher HD3101DR
check out www.pressureparts.com
Posted on Jul 08, 2008
  • 174 Answers
SOURCE: clean and unloader valve on Karcher hd3500
Hi:
Cleaning it is not enough. You need to make sure the o-rings are in good shape and grease it with a very very good waterproof grease. Here is a schematic of the pump. The unloader is parts 7 to 13 on D-2
Posted on Sep 10, 2009
  • 56 Answers
SOURCE: how to clean unloader valve..
The Karcher K2400HH and G2400HH do not have an unloader valve, they have a spill valve which is located under the black cap on top of the pump.
The spill valve needs to be removed and the side walls of the hole it sits in need to be wire brushed to remove deposits. then you can put it back in and put the pump back together.
Posted on Dec 31, 2009
My Karcher 530M runs ok until I release the trigger, then it will not start again unless I switch and allow the water to run through for about 15 secs before switching on again
Hi Cliff:
My experience is that the pump pressures prevent the engine from starting, so we hold the trigger while starting.
My brother has cut a wedge of wood that he uses to jam the trigger open to bypass the problem. It can get a bit wild if the wand is not secured when the unit is started..
Aug 10, 2016 | Karcher Garden
Karcher 2500ph pressure washer spill valve has been replaced pull wand trigger pressure good for 3 or 4 seconds drops off for a second or 2 goes back to good pressure for 3 or 4 seconds drops off again for...
If you have a Karcher then you should always post your machines barcode.
full article on nozzles :
http://repairshed.blogspot.com/2013/09/pressure-washer-lance-nozzles-what-you.html
The spill valve operates at approx 20% higher than specified pressure washer operating pressure. If you have any lance issues then the pressure could be running higher than specified (machine running at same pressure as spill valve operation pressure)
your machine produces a fixed flowrate of water (maybe 8 litres per minute) and your nozzle is a fixed size. the diameter of the nozzle determines the back pressure. A piece of debris could further close your nozzle orifice and increase the back pressure. Using a new lance that has the wrong nozzle fitted can also cause this issue.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 15, 2013 | Garden
Karcher K4.97M electric waterblaster cycling
It sounds to me like the unloader valve is bypassing internally.
Nov 16, 2009 | Karcher K2.26 Electric Power Washer
I just bought a 2nd hand honda excell psi max vr 2522 2.2 gpm max 5.5 hp gvc160. i put gas and oil and it wouldn't start?
Have a helper hold the trigger of the wand open while you try it again. If it starts that way you have a sticky unloader valve in the pump. DO NOT RELEASE the trigger for more than 10 seconds if the engine continues to strain when released! If the engine doesnt run freely when you let go of the trigger, pull it again and shut down the unit!
Add some power steering fluid to your supply hose (about 3 or 4 ounces at a time) and restart the unit with the trigger pulled. Allow the oil to flow through the pump for 1 - 2 minutes for each treatment. Several treatments should make the pump and valve happy again.
Hope this helps.
Sep 25, 2009 | Karcher 2500 PSI Pressure Washer
The engine on my Karcher K2.26 turns on when you turn the switch and continues to run rather than just when you pull the wand trigger. Lower pressure also results.Any solutions?
yea mate ya bypass will be stuck(the little valve that turns the unit on or off) also if not that there is a little micro switch attached to the valve this may of dislodged for some reason... commonly happens if unit has sat for a period of time not used
regards
brad
Sep 07, 2009 | Karcher K2.26 Electric Power Washer
Karcher K3.91 compressor run for a few seconds every 10-15 second
They have a problem. I removed both valves and lubed with lithium grease as I was told. Unit is now working for how long who knowes.
May 18, 2009 | Karcher PSI Electric Pressure Washer
Karcher 2400 psi blaster When you release the trigger it will not pick up pressure when you use it again
To determine if your problem is due to an easily replaceable part, follow these steps:
1. Connect the water supply hose, the pressure hose, and the wand WITHOUT any nozzle tip.
2. Turn on the water supply, and press the trigger until water is smoothly running out of the nozzle
after any air is all purged out. Release the nozzle trigger.
3. Start the engine, and let it warm up for about 30 seconds.
4. With the engine running smoothly, press the nozzle trigger. The water should flow out of the nozzle (without the tip installed) at a faster rate, while the engine noticeably loads down as it used to do before your "no pressure" problem. If it does not load down, turn it OFF, and disconnect everything, and contact a Karcher repair facility.
5. If the engine does load down, release the trigger, and install one of the nozzle tips (not the black one).
6. Press the trigger, and the engine should load down, and you should have normal pressure from the wand. After you release the trigger and press it again, you will probably again have no pressure, and the engine will not load down. Removing the nozzle tip, pressing & releasing the trigger, and re-installing the tip should give you normal pressure again, but releasing the trigger will cause no pressure until you again remove the tip, press the trigger, and re-install the tip.
This is caused by a bad UNLOADER VALVE, which is located under a black cap with a metal button on it located on the top front of the pump. I don't know if you can purchase the replaceable parts from a Karcher repair shop, but when a neighbor & I took his washer to a repair place, it looked pretty simple to do this repair, and he was charged about $60 to replace a $5 (maybe) part, and it took about 5 minutes.
Sep 12, 2008 | Karcher 2500 PSI Pressure Washer
Karcher Power Washer Problem
I had the same problem with my Karcher. The recall was lifted Aug. 0f 2007. Tried numerous people at Karcher....head of Customer Service, vice president, etc. No one returns telephone calls not even cutomer service....poor, very poor customer service. Thinking about calling Germany.
Jan 11, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
Top Karcher Garden Experts
John Trevino
JOHN LAPIER
Joseph Mueller
Joseph Mueller
Are you a Karcher Garden Expert? Answer questions, earn points and help others
