SOURCE: indicating steady red light can not charge
Rub the terminals of the battery with your fingers and than again put it on charging .... before doing that remove the battery from the cell for an hour..
SOURCE: Bluedio T9 Bluetooth won't charge
Well... I've got the n65, and this is the third time I've gone to charge it. Solid red, won't turn on no matter how long its been plugged in, can't find the manual, this fixya page is the best result online...so my solution is to stop by the local cell-phone accessory shop to buy something new.*
*Results may vary. :^s
SOURCE: when I turn on my
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
SOURCE: Hitachi 43FDX20B 43 in. Rear Projection Television won't power on.
check for a bad lamp then make sure the fan is working.
