Refrigerators Logo
A
Anonymous Posted on Apr 06, 2019
Mfx2570ae. Fridge has been unplugged for some time. Cannot get water to dispense.
Can hear the selinoid engage when pushing water button. Tried the prescribed push for 5 seconds the release for 5 seconds and repeat over and over, but no water. Water line is fine. Water filter was in the fridge when bought used. Have ordered new filter.
geob91
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Refrigerators Expert 128 Answers
  • Posted on Apr 06, 2019
geob91
Level 2:
Passionate:
Answers
128
Questions
0
Helped
83393
Points
414
Is it safe to say that the water was also shut off for some time? Did you check to make sure that it works? I usually turn it on with the tube in a bucket before hooking up to the refrigerator just to be safe! If it is a cheap saddle valve, they are known to break off in the pipe not allowing water to flow.
5 Related Answers
Anonymous
  • 489 Answers
  • Posted on May 11, 2008
SOURCE: I have an LG LSC26905TT side by side fridge
When the filter freezes up, the outside casing may have cracked and will leak water when you dispense water through the door.  You will need to have the filter replaced and that should take care of the problem.  But the filter should never have frozen in the 1st place.  You will need to call a qualified LG technician to see what's going on inside the refrigerator.
John M. Pere' Jr.
  • 55 Answers
  • Posted on Aug 31, 2008
SOURCE: Frigidaire FRS26ZSH no water at dispenser or ice maker
  1. I would remove both solenoids (one at a time-not to mix them up) pay attention and mark all parts- try cleaning or replacing them. Most are fairly common supply items. Paying attention to wiring and proper installation is important during re assemble. JOHN-LA
Anonymous
  • Posted on Jan 11, 2009
SOURCE: Water filter stuck on my Kenmore Fridge
I had the same problem. I coudn't get the knob to turn. I ended up taking the front grill off so I could get a better grip on the knob. Once I did that I still have to put a lot of pressure on the knob to turn it but that did the trick. When I got it turned a quarter turn then it was easy to pull the filter out. Hope this helps!
Anonymous
  • 18 Answers
  • Posted on May 29, 2009
SOURCE: Viking fridge water and ice not working
Yes....a totaly clogged filter COULD cause the problem, but the water solenoid may be the culprit. I'd call a service company to look at it.
Anonymous
  • Posted on Dec 26, 2009
SOURCE: Fridge Makes Cubes But No Water
Get part number WR49X10173 from Consumer Relations (800-386-1215. (Free; be sure they understand how long you have had to deal with this issue) ($38+ if you buy part on line)
The part includes instructions to install, but not how to remove the control panel. Here's how: Look from below the panel to observe 3 holes (aprox. 1/8" dia) located in a long narrow depression. Observe that there is the edged of a plactic tab visible partly covering each hole. Use a pointed tool such as a shish-kabob skewer to carefully probe the hole at the right or left end, and carefully pull the control panel forward on the side with the hole you are probing. This will help release the tab, allowing the panel to come off. Repeat for the opposite side.
The instructions with the part take over from here. The part is a loop of wire that provides a bit of heat to keep the area warm, and is held in place by some aluminum tape, then spliced into the red and the black/white wires on the 6-wire harness on the left side of the control. BE SURE the power is OFF!!!!
Why would my Maytag MFX2570AE 4 door french door fridge motor/fan run constantly?
if the compressor goes off and only the fan keeps working thats broken fridg but fan is not a big energy drainer on bill if the compressor works allways it might be to hot in the room or door is not seald or totaly closed give it a strog push when closing or maybe you have under floor heating so you have to insulate bottom from heat or maybe its not insulatdd well from heat of compressor
Control panel failure
Have you tried unplugging and plugging the fridge back in? This may reset the control baoard.
I push the water dispenser and no water comes out but comes out at the bottom?
The hose to the water dispenser up front cannot be connected and it is spilling the water onto the floor when the solenoid is activated.
1helpful
Refridgerator Not Dispensing Water
did the water work before you changed the filter . water when chilled may have frozen in line. . i would before major work adjust tempt of both freezer and frig . if too cold / forzen line .. are you freezing any thing in crispers. this is a good clue.. hope this might help .. mm
2helpful
Ge gss25ifrf ww side by side fridge clicking
Sounds like the main control board is bad . Pt # WR55X10656 . This board is located behind the 8 " X 10 " , panel just above the compressor compartment . The compressor relay , is what you hear clicking , cutting the compressor , on/off . Even the dispensor board , is operated by the main control board .
Water dispenser won't stop. It started automatically and water keeps being dispensed even though we tried pushing the ice button and the lock button. It stopped when I opened the freezer door but would...
I take it this is a G E refrig ? Model number would have helped . If you still hear a hum with door closed , the microswitch behind the dispensor board is bad . Not a computer problem but a simple fix .
1helpful
1helpful
3answers
In door water and ice cube not working
Water dispenser is a simple touch switch in door energizing a solenoid water valve behind ventilation grate above refrigerator. Water tube runs down into and ends at ice dispenser chute. Should hear solenoid click at top of fridge when activate water touch switch. Can unhook discharge side of solenoid valve temporarily to prove water output. If water dispenser tube acts blocked it could be frozen where it ends-look up the hole at the bottom of refrigerator control buttons.
Ice maker is totally different system. No clicking when push ice button but ice in bulk tray may mean the simplest of malfunctions: Ice bin not pushed in the last half inch if ice auger not lined up with drive pegs. There are hidden switches behind ice bin that need to be engaged or nothing will happen in the ice maker: no auger noise, no clicking, no new ice making. Ice bin will be flush with sheet metal if it is in the right spot. Also plastic juice rack won't hang properly if ice bin not pushed in all the way.
Water dispenser and ice maker
you got it replace the water inlet valve but make sure it is bad first ...................The loud noise you hear maybe caused from too much pressure on the valve turn the pressure down a little and try again
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
