The wiring harness diagram for connecting the AVH-X2500BT receiver to the car wiring is shown on page 46 of the owner's manual. Crutchfield has the manual on the product page: https://www.crutchfield.com/S-KZq3UpLmFAw/p_130X2500BT/Pioneer-AVH-X2500BT.html . Look on the right hand side of the page on the Overview tab. The link is below the "What's in the box" header. The direct link to the manual is currently here: https://pdf.crutchfieldonline.com/ImageBank/v20130710152000/Manuals/130/130X2500BT.PDF . You can also find the manual from Pioneer on the archived receiver manual page: https://www.pioneerelectronics.ca/POCEN/Car/ch.DVD-Receivers.Archived .
I hope this helps.
SOURCE: pioneer avh-6400cd
Go to Pioneer site to down load the hardware manual for it, it should include the wiring diagram. Good luck.
SOURCE: watch a dvd while driving pioneer AVH-P4000 DVD
Hi Dave
No ....go to a hardware store buy a toggle switch than get a single speaker wire (small wire) attach it to the red wire on the back of your pioneer deck (make sure to leave the red wire in back of deck as well) and attach it to the power on the toggle switch do the same with the black wire (ground wire) the black wire will go into the toggle switch under the power wire. finally install the parking break wire from the pioneer unit to the last slot on toggle switch and this should do the trick if not swap the ground spot for the brake spot on toggle switch >>>> MAKE SURE THE TOGGEL SWITCH HAS 3 HOOK UPS to do this correctly (your system will provide sound with the toggle switch off (Blue Screen) but when toggle switch is on you get video while driving) good luck
SOURCE: NEED WIRING DIAGRAM
hope this helps,......http://www.nodevice.com/user_manual/pioneer/car_multimedia/avh-p5700dvd.html
SOURCE: help i need a wiring diagram for a pioneer
ftp://extra.abt.com/PDF_Files/avhp5700dvd_installation.pdf
This is the installation manual for the AVH-P5700DVD, including a wiring diagram for the wiring harness.
http://www.pac-audio.com/PACProductData/TR7/1_Instructions/tr-7_instructions_010505.pdf
This is the wiring diagram for the PAC TR-7 UNIVERSAL TRIGGER OUTPUT MODULE VIDEO BYPASS.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
SOURCE: need a wiring diagram for Pioneer AVH-P5700DVD
here u can download user manual and install guide
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
