I doubt it, possibly, call them to verify but if so they won't be this affordable- Check this link out & this will handle all of your needs as far as adjusting the carburetor amongst other things on virtually all small engine! I couldn't find them locally so this is what I ordered & no regrets!
https://www.amazon.com/TOPEMAI-Carburetor-Adjustment-Screwdriver-Carburator/dp/B07GKXXRLC/ref=asc_df_B07GKXXRLC/?tag=hyprod-20&linkCode=df0&hvadid=309813767497&hvpos=1o1&hvnetw=g&hvrand=8047595239073093085&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvl
SOURCE: need adjustment tool for carburetor - where can find this
Hi
You can try to buy it from a shop where are Poulan chain saw for sale but I am not sure they do.
best rebards savumihai71
SOURCE: carburetor tool
Unless you are skilled enough to make your own, you are stuck taking the saw to a servicing dealer as they are the only ones allowed to possess the necessary 'D' head screwdriver. Give thanks to the EPA for mandating the prevention of mal-adjustment pollution.
SOURCE: can not adjust carburetor
Yes...they have them on Ebay. Normally you won't be able to get one from a small engine repair place or dealer unless you're "in" with them. You can make using a 22 gauge-18 calibre electrical connector. (Quick disconnects-female) They need to be female spade terminals and you can stick um on the end of a screw driver and then push them down over the round-splined heads of the L and H adjusting needles on the carb. Probably have them at auto parts store....if not Radio Shack.
SOURCE: I have a small 90deg
Possible it's attached to your throttle body? Clean your throttle body while you're there, will get rid of rough idle.
My name is Dane and I am going to assist you in solving your problem.
You probably have a clogged Carburetor. To clean the Carburetor, you will probably need to remove, disassemble, soak, and use compressed air to blow out the jets in your carburetor. Pay close attention to how the carburetor is attached to the engine. Make a drawing if you need to or take some pictures. Remove the Carburetor from the engine. Remove the air filter, linkages, throttle/choke cables and fuel lines as needed. Remove the mounting bolts/nuts. You will need to disassemble the carburetor as far as possible and put it in some Carburetor cleaning solution. You can get this at any auto parts store. Do not place rubber parts in the solution. Allow it to soak in cleaner as directed, and then blow out the ports and jets with compressed air immediately after you take it out of the cleaning solution. Be careful not to get any spray back on your skin or in your eyes. Reinstall the Carburetor in the reverse order. Replace any worn or torn gaskets or o-rings as you assemble and reinstall it.
If it starts after you are finished with the cleaning, but still runs a little rough, you will need to adjust the high-speed mixture setting on your Carburetor. Turning the high-speed screw out just 1/2 turn or so should do the trick. It is not so hard to adjust the Carburetor, however you do need a special tool that is very hard to get your hands on. They don't make many engines with plain screw heads on the jet screws anymore. The newer Carburetors are factory set lean so they can pass emission standards. If you have a local dealer, they should adjust the mixture for a couple of bucks. If you can adjust the screw, start the engine, allow it to warm up, and apply full throttle. Start backing off the screw just until the engine gets max RPM. That's it. You're done.
Just a TIP: Always mix your fuel with an approved fuel stabilizer. Fuel begins to go bad after a few months and that's why many people have fuel problems in the spring.
I hope I
