If you have got your emergency keys you can pry off the panel with the keypad and open it from there. The keyhole is hidden behind the keypad.
Here have a look at the manual, page... 8 has what you need.
http://images.harborfreight.com/manuals/95000-95999/95685.pdf
Have you tried dynamite?
SOURCE: bunker hill safe
i had the same problem this is what i did. i took the lil leg off the bottem it held on by a srew take a cloths hanger put it in the hole and now u can hit the lil button that is for makin a new code it is on the hing side of the door the yellow light will come on and stay on now put ur new code in then hit a or b i used 1111a then changed it once i got in o by the way ''the factory code is 159a try this first" and the cloths hanger i shoved a ear plug on the end of it so that way it could grip the button hope this helps somebody
SOURCE: Cannot get my Bunker Hill Safe open.
get the key number that is listed above the key hole and then call 888-299-3427 for a replacement
SOURCE: Changing Combination of Bunker Hill digital floor safe
there is a button on the inside of the safe. press it and enter new combination on keypad. Easy enough
SOURCE: My husband locked both keys in the safe 94985...
Search on "How to open a safe with a potato" and you'll find a youtube video on how to open that safe. All the Bunker Hill safes use the same lock mechanisms which have a critical design flaw if the spring on the solenoid is weak in that the plunger bounces enough to allow the bolt to be thrown open if you can time hitting the front of the safe just right. Of course, if you mount it such that you can't get a good swing in then no problem. There are two adjustment screws to the bolt throw, if your safe is easily opened this way, you might want to adjust these screws so that more of the plunger hits the stop. I couldn't get mine to open with a rubber mallet but it's mounted so you can't get a good swing in.
SOURCE: have a bunker hill safe. battery died. lost
Remove the sticker on the front panel with the SKU number, behind it will be a small hole, use a small screwdriver to remove the screw, then carefully remove the number pad. You will see the place to use your key.
Use dynamite...
Thanks Ben
