The "beater height" may be set too high causing interference with the lock mechanism. Please see the following kitchenaid instructions on how to adjust beater height.
https://www.kitchenaid.com.au/blog/kitchenaid-tilt-head-stand-mixer-beater-bowl-clearance-hinge-pin-adjustment-0
SOURCE: the locking pin on the
I had the same issue. I just finished tearing mine apart only to find that the lock just wasn't engaging with a slot in the base of the mixer. Try lifting up the head of the mixer to expose the height adjust screw in the hinge between the base and the head. By tightening mine down a couple of turns, the lock can engage the slot again and the lock works. You may have to do a little tweaking to find the right balance between height adjustment and latch functionality, but at least you won't have to tear your mixer apart like I did!
SOURCE: doesn't lock tight. bounces
is it the bowl that bounces . if so the beater is bent or not in properly .. ck these ..
