There is a sharp rock beginning to poke its way through my pool liner. The vinyl patch from the repair kit won't lay flat on the rock so it doesn't stay put. My pool is currently full of water.
If you go down to the bottom of the pool with a small block of wood (make sure the edges are rounded and sanded) and a hammer you can probally hammer the rock back into the ground. If you just pound it flush you can probally patch it just fine at that point.
Tap around the rock to loosen up the first around it, then with your thumb push the rock back down into the ground. Be careful!
***Tap around the rock to loosen up the DIRT around it, then with your thumb push the rock back down into the ground. Be careful!
