Question about Samsung Televison & Video
How do I program my Suddenlink reremote to control the volume on my Samsung sound Bar?
    Top Expert:
  • Samsung Master
  • 9,985 Answers
Make sure in audio settings sound bar active and on adjustable volume
Posted on Apr 13, 2019
SOURCE:
  • 6 Answers
SOURCE: Cable Set-Top Box remot won't change sound vol. Only TV Rem. does
They volume indicator you are seeing is meant to show the volume of content if it were to be recorded on the cable's dvr. This indicator has no effect on the volume of content as it is being watched. This feature allows recording of sound at a set volume even while the tv is off. It sounds as though you'll just have to use the volume buttons on your tv's remote, though you might want to try seeing if there is alternative set-up for those cable volume buttons.
Posted on Jan 05, 2009
DickCanFixIt
  • 948 Answers
SOURCE: volume control program installation
Go in to your Control Panel. Double click SOUNDS AND AUDIO DEVICES. Check the box near the center that says PLACE VOLUME ICON IN THE TASKBAR. Click APPLY, then OK.
Posted on Mar 17, 2009
Testimonial: "thanks **** now can you tell me where to get the fixya community toolbar i sure would like to have it back "
dunnbiker
  • 8546 Answers
SOURCE: How can I program my verizon cable box remote
Consult its directions to see if it has a variable audio output, then use it.
Posted on Jan 28, 2010
danbusa
  • 185 Answers
SOURCE: I HAVE A VIZIO SOUND
Hello, Daniel Busa with Dish Network's customer service try these steps if the remote will program this will do it
Posted on Dec 29, 2010
alicantecoli
  • 22484 Answers
SOURCE: sharp ht sl50 sound bar and woofer no volume control
you need to connect the sound via the scart lead plug ,on the polug if you connect the sound to pins 2 and 6 for the channels and 4 is the earth or dround but check it out with a scart diagram as i cannot remember correctly and i just looked for my chart and cannot find it as its been a long time since i was involved in setting up satalite/video/TV euroconector cables .
Posted on Dec 26, 2011
How do I change the volume of my sound bar using the harmony 650? Right now the volume button only changes the volume of the TV. I have an LG tv and a Samsung sound bar connected by blue tooth. Thanks
You have to program the remote for the sound bar then only you will be able to control use it wit sound bar.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Nov 26, 2016 | Samsung Televison & Video
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
Suddenlink tivo apex tv code
Hi- My name is Shannon and I am with Suddenlink. The SL-TiVo remote can be programmed to control the TV and one other A/V device using these steps:
1)
From TiVo Central, select Settings & Messages > Settings > Remote, CableCARD, & Devices > Remote Control.
2) Highlight Part 1: TV power, volume, and mute and press SELECT.
3) The DVR displays a list of television brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your TV brand and then press SELECT.
4) The TV Remote Codes screen appears. Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the TV.
5) If also programming to control volume & mute on an A/V receiver for surround sound; Highlight Part 2: A/V volume and mute and press SELECT.
6) The DVR displays a list of audio/video receiver brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your receiver brand and then press SELECT.
7) The AV Remote Codes screen appears.
Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the receiver.
The TiVo remote will now turn the TV on/off and switch inputs and adjust the volume and mute the audio on the receiver.
If you have any questions, feel free to email me at shannon-AT-suddenlink-DOT-com. Thanks!
Nov 23, 2012 | Televison & Video
I need to program my suddenlink remote code to work for my motorola suddenlink cable box so that my volume button can work.
Hi- My name is Shannon and I am with Suddenlink. If you are still having trouble programing your remote, you can find all the codes on our Suddenlink Support site, here: http://help.suddenlink.com/Television/Pages/RemoteControls.aspx. Thanks!
Nov 19, 2012 | Televison & Video
I NEED CODE FOR SUDDENLINK REMOTE
Hi - my name is Ashley, and I'm with Suddenlink. For Suddenlink remote control programming codes, please visit this site: http://www.urcsupport.com/html.php?page_id=289
If you have any other questions, please feel free to contact me directly: ashley-AT-suddenlink-DOT-com. Thanks!
Jun 26, 2012 | Televison & Video
WHAT IS THE REMOTE CODE # TO FIX A NEW SUDDENLINK CABLE REMOTE
Hello - my name is Ashley, and I'm with Suddenlink. If you are attempting to program your Suddenlink remote to control the channels, or volume on your TV, please go to this link for instructions: http://help.suddenlink.com/Pages/Category.aspx?ServiceId=b0097608-a864-46d1-a502-5e067bdac28d&CategoryId=0x010100C568DB52D9D0A14D9B2FDCC96666E9F2007948130EC3DB064584E219954237AF3900242457EFB8B24247815D688C526CD44D005DA7DADD0187844E868223CF85F216550805000A07F3FC69F58E45B744E78526EC233D
If you need further assistance, please feel free to contact me directly: ashley-AT-suddenlink-DOT-com. Thank you!
Apr 19, 2012 | Televison & Video
I have suddenlink services and a scientific atlantic box and there controler will control the channels but not the volume
Hi - my name is Ashley, and I'm with Suddenlink. I'm sorry to hear that you're having some issues with your Suddenlink remote. I would be happy to work with management in your area to resolve. Please feel free to contact me directly: ashley-AT-suddenlink-DOT-com. Thank you!
Jan 29, 2012 | Element Electronics FLX-3211B 32 in. LCD...
Verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
Feb 20, 2010 | Samsung Audio Players & Recorders
Televison & Video Logo
35 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
