Can it be replaced with removing water heater 10gal attwood
SOURCE: I have an Attwood GE 16TE hot water tank with what a bad element,
this is not a typical unit, you might want to consider calling the company for directions, go to there web site if they have one and look for elements and where they are located
SOURCE: bosch 25e water heater wont ignite
combi or standard if combi pressure too high and will be blowing off your high pressure release valve which would stop your boiler from igniting best of luck
SOURCE: How do I access and change the thermocouple on my
If it is like a standard water heater, it will be mounted right in the flame of the pilot. There may be a bracket holding it or a clamp with a screw. If you can get it out, the other end is held in by a brass screw into the gas valve.
Once you get it out, an RV outlet or plumbing supply house should have one.
